hello we you could spend the ROM (david344)please!!!
.Had. A taste of this ROM and discovered is beautiful Ness but unfortunately had difficulty flashing GApps as they were formatted in a signed zip???)(basically a download with the icon looking like a piece of paper) and when I went into recovery n my ex SD card, it wasn't there??? So I went back n see what I can do and compressed the file in a zip format(icon with zipper on the. Piece of paper...) . This time the file was readable, but when I flashed it, twrp said it failed.
U should be able to use it cus its from an European or korean version ported--- just make a bakup of urs n flash it ifit doesn't wrk u can go back--- u would need the orange apn to set it up-
@@@ Xt51....So can u tell me from where is the phone. That the source. Was pulled from?
Succesfully installed CM11 on my MS500
It's been running nice even tho it has some bugs.
-My device restarts when I try to add a new contact.
-Black lock screen.
-I didn't find a way to move apps to ext.SD.(Will this feature be available in a future versi
-Black lock screen.
There is a build that works pretty frickn smooth, so long as you flash it correctly apparently. It's was made by codingninja. No black lock screen o death, no kernel crashes, the most stable rom we've had. And even though new builds have surfaced, it seems ppl still experience the problems found originally on the first few betas, so I've stuck with this one and couldn't be happier. My Daily driver and just 1 half of a bug away from being considered complete and stable. Look in the forum for it.
There is a build that works pretty frickn smooth, so long as you flash it correctly apparently. It's was made by codingninja...
