Root [MetroPCS] [ROM][F6] Xperion ROM **Updated 2/11/2015**
Heycjist wondering if there was a way you could implement a louder volume hack for everything on the besides just Apollo player. The phone volume when listening through the head jack is so low. Oh and thank you for all your work.
I use viper4android, I think its great.
Do you have to keep installing the driver every time? I tried installing the driver and it completed. And I restarted my phone but it still asks me to install the driver
I use it to. I have use Viper4Android since I had my LG Optimus L9 and thie F6.
I never had a problem. you might have to reinstall it..
How do I unroot this ROM? I like the ROM and would like keep it. But, I need to use Good for Enterprise and it does not work on rooted phones.
Hey yall,
I don't see the instructions that say to root 0i than, install voodoo root keeper, TWR, update 12b
Over at GTs site all I see is...
Instructions:
  1. Boot into recovery.
  2. Do a backup.
  3. Wipe data/factory reset.
  4. Install rom zip from external SD.
  5. Done. Reboot.
So does this still need updated 12b Firmware or can I just do bkup and install from 0i?
Yes and thanks very much!
Hey yall,
[/LIST]
You can flash the rom over 10i firmware by following the rom installation instructions, but it is recommended to update to 12b firmware first. It's up to you.
Just a bug I noticed. Task managers background is black and so is the text i.e. illegible.
You may have gotten a bad download. Download the rom again, I just switched the link.
Task manager is white with black text...
Screenshot:
I'm still running some build from July. Maybe that's it. Not a big deal for me.
That build.prop link you posted for AOSP lockscreen is what's causing your issue by making the font black in some areas. That's why I told you I did my own version of aosp lockscreen for the latest rom update which doesn't have that problem. ;)
Hah, figures. I would love to update, but having to install/setup everything again every time is a huge pain. I'd update more often if they were incremental updates rather than full.
Same way I feel! I still haven't updated since june cause I'm lazy...lol:rolleyes:
But the fact that GT is a "stone cold LG killer" makes me have to!:smokingsomb:
Xperion is the only ROM thats been hit with pestacides (bugless) for this phone! I get occasional reboots, but I mean occasional!
An one other thing... This will be my last LG cause of these issues we're having!
"kit kat exp. isnt flashing, says aborted?"
Read first Dummy....lol.. I don't use nova!
Days like this confirm I have brain damage!
I'm havibg trouble restoring apps? says there is not enough space?
Re-did the apps2SD an still having trouble?
I erased 4 apps that I had previously an still cannot install another!!!
After all that its an issue with Chrome not installing ever thing else is????
Is the newest version of this ROM supposed to allow a transparent status bar? Nova launcher says my system doesn't support transparent status bar
The nova feature you're talking about is for kitkat which nova says you need in the setting.
To make your status bar transparent you have to use the Xposed module "GravityBox" which is included in this rom.
Happens to me and a lot of others as well.
If I'm Not mistaken, that happens because when in a call the proximity sensor is activated and detects when something is near then shuts the screen down. It does that so the screen doesn't stay on while against your ear. Its a pain when typing in pins while on a call though, but it is normal.
[I lost the thread on this] Is there any "strategy" you use when this occurs? i.e. Does orientation matter? I usually end up "stabbing" at the keys - finger away and then quickly in, but it is usually frustrating not to have a working "strategy" to deal with this. My phone has even rebooted itself during this process a few times. But, I don't know if this is causing the reboot?
still having a apps2SD problem? cannot figure out what is different but Phone wont hold all my apps anymore?
I can't help you with that, I don't use apps2sd. Most users are using link2sd and some are using it in combination with apps2external script. I don't use any of that, but you can use one of the following 2 threads to troubleshoot your issue...
http://androidforums.com/metropcs-o...root/847053-guide-easy-how-setup-link2sd.html
http://androidforums.com/tmobile-op...od-app2external_sd-fixed-duplicate-files.html
I meant link2SD..lol I'm trying different ways, eventually I'll get!
