Help Micromax A70 General FAQ and Discussion
i ashutosh.. has purchased micromax a70 n it got bricked. I rooted my phone using z4root n then few days later I tried to install boot manager with which my phone got struck in bootloop.. and was not starting. I had CWM installed but evn thn I was not able to boot in recovery it jst showed micromax logo nothing worked nor pressing vol+ key n power button worked. I have java n android sdk installed on my pc. its windows 7 please help me. to unbrick the I don't know the procedure to unbrick it pls hlp me pls...
video playback problem :| :|
some videos play well but some hangs and audio continues
video config is 480p mp4 bitrate 768K
R u playing vids in hardware decoding mode, if not then play through HW mode(use mx vid player)
Coz
480p mp4 with any codec and bitrate upto 1024 plays well in a70..
If it dosent play through HW mode then check audio is in aac or mp3 coz mp3(4video) is not supprted in our device
Hi any one has tried to use dt a2sd from Hybrid v3 ?
i have noticed posts regrading how to remove it but any one has sucesufully used it...
caz i am unable to !!!
my phone just gets stuck in boot loop !!
Its easy there's a tut. Out there just follow it :)
Nope it works with some problems from the given version
when i used it i do not know why but the phone got into boot loop then i flashed the latest beta of same and now it is working awesome on Hybrid v3 !
so at-last bye bye to link2sd !
I think @cool.gautam just add link for dt a2sd 2.7.5.3 beta 04
from
[Script][A2SD]Darktremor 2.7.5.3 Beta 04 [MT4G] (01/29/2011) - xda-developers
it works after i flashed the same ...
know not many ppl want dta2sd hence it is not necessary ...
from
hmm....!! well , i'll see to it :) thanks by the way
this could be the new logo for micromax company
question 1---->if after rooting I perform factory reset using recovery what will happen???? :)
question 2---->if after rooting I uninstall apps using titanium backup then without restoring those apps,perform factory reset using recovery what will happen???? :)
question 3---->if I restore all uninstall apps using titanium bcp then perform factory reset using recovery what will happen???? :)
I am using stock recovery not clockmod recovery :D
well,
1.) after rooting if you perform factory reset your rooting will still be there i mean your phone will remain rooted for unrooting you need to unroot it via same or similar app !
2.) after factory reset only user installed apps are deleted more over once u delete the apps from titanium backup even after a f.reset those apps won't come back -- for that you need o flash entire a70 rom again which is avaliable in the same forum
3.)if u restore all the deleted apps then do a f.reset they will remain intact if they are converted back to system apps ! note again only user apps are deleted not system apps after f.reset
i am getting call drops on my a70 in between a call the phone goes off. the power buttons also dont work. it comes back on removing and reinserting the battery.?????
also does A70 have a magnetic sensor for the compass?
pls help....
pls help....
No magnetometer...
No clue regarding call drop...
after I boot I hav 80+mb free ram but after using for half-day or 1day i hav only 60+mb free ram available...ne way to get more ram??? ne script????? I am using stock rom...
