Help Micromax A70 General FAQ and Discussion
Yup simple restart must solve the problem also try QUICK SETTINGS from Market -- free !
this app solved my Connection disconnection issue long back !
As i see it it is impossible for CWM 5.5+ to be ported to A70 without source ....
it need to get access to custom modified kernel !
just few days ago it was launched for just 2 devices now for many devices !!!
btw it is gr8 ! ( not better than 4ext recovery anyways for higher device !!)
Restarting is not helping me still my bluetooth is not switching on restarted my mobile a thousand of time.Please somebody help yar I don't want to go to micromax service centre they have pathetic customet service..
In recovery mode there were 2 option to wipe cache one was for factory reset and the other just wipe cache..So I did'nt do factory setting but wiped cache was that dalvik cache??
i would suggest try quick settings app
and more over
you are on a wrong path !
You have not installed any custom recovery for the phone first of all you need to install Either CWM 4 or CWM 5( recommended)
Install it from this thread : http://androidforums.com/a70-all-things-root/461765-tut-installing-cwm-recovery-v5-0-2-6-a.html
then do a nand backup (very imp. ), then you can proceed with a dalvik clear followed by flashing any other ROM afeter a factory reset !( you can restore just the data after a Factory reset [note: everything i have typed is mentioned , the procedure is mentioned in the same the same thread ! ] and if flashing any other ROM does not help try multiple flashes ! but if this does not help you are very lucky as your phone will not disturb you in your work for least 3-6 months ( at service center :p ) caz they are COMPLETELY new new for droid phones more over if rom fashing does not help you cannot get anything after flashing a software at the service center as they do the same exact process you are going to do !!!! just flash everything again....
One more thing i will strongly recommend you to use the fastboot method for flashing ...
No about that I want to ask you a question I want to flash that asevenmaxx rom ok but the links for that has kernel files only where is the rom??
why you want to flash asevvmaxx? its not bug free rom , it's wifi not working , no music bug corrected and many more GO FOR HYBRID3
Ok but where is the hybrid 3 rom zip file???Again by clicking on hybrid 3 link we are directed to asevenmaxx where only kernel is given??
In order to flash a rom we have to copy the rom zip to sd card..So what does that mean how to move it to the root of sd card??
Root of the SD card means you have to copy in Memory card straight away not in any folder if your mem. card is in H drive then put it in H:\
