How to know abt gps configuration..a75 has a menu in settings to enable/disable a-gps.but not a70?i want to know what are default configuration of gps n how to change if i want to?
in location n security we can just enable or disable gps module.i m asking abt configuration cause as i remember gps does have some configuration modes.don't remember exactly...let me find it.its there some where i remember but i cannot recollect it
its some where in settings .... location and security i guess
Ok,i have found what I was looking for..gps.conf n loc_parameter.ini file in /etc.
Plz someone provide me fm.apk coz i accidentally deleted it & there is no alternative for fm in market
if my fm app got deleted then it wouldnt affect me coz fm doesn't work in my a70!!!! I have never heard a song using fm,from starting my fm doesn't worked!!!
fm works on A70 ,
u need to insert headphones for it .
help ...my phone is showing damaged sd card....but its working on other mobiles and my pc too....
That's not a problem of rom or phone.it's ur wifi modems settings.wifi problem
i use net on pc thru wifi
whenever my pc is on and connected thru wifi, wifi on mobile works awesome
but whenever i turn my pc off leaving the modem on.....then connect mobile thru wifi, it disconnects and connects after a gap of 5-10 secs.......it annoys a lot.....
tried le andros 2 and hybrid 3.....
prob in both roms......plz help
Well then may be it's not working properly, can't say for sure..
Backup sd card content, format sd card n then try...n if u have previously installed same app from some other source then its signature can be a conflict,uninstall it n then install from market.Hey guys while installing many apps like talking tom from the market after the installation is complete I get an error sayin couldn't install on usb storage or sd card what to do abt it pls help
