Granite1
Zercron Encrusted Tweezer
Ok folks, I wanted to share this old trick for battery life because I sort of forgot about it. Well I didn't forget about it, I just stopped using it as much.
If you have one of the newer roms with the dropdown settings menu in the notification bar this is really easy. If not add a mobile data toggle widget to your homescreen.
KEEP MOBILE DATA TURNED OFF.
Only turn it on when you check your emails or surf the web, etc. Turn it back off once done. This saves a s&!t ton of battery. I'm over 9 hours with 75% left. Almost 2 hours awake time and over an hour of calls. Not to mention forum parousing.
Turning mobile data off when you don't need it will increase your battery life substantially. You still get calls and standard text messages, mms messages won't download of course, but you'll get the text that It's there. Also don't pay attention when it says mobile data takes a little while to turn back on....WRONG! It's connected almost instantly. Turn it on, hit your browser and its loading right now.
Had to post this, just started using it again, and I forgot how good it works. Enjoy!
If you have to turn data off just to conserve battery power and then turn it it back on to sync data, what a pain, imo!! You might just use more power syncing when you turn data back on.
