Root Need HELP - A2SD partition corrupt.
midmadn
I have a 16 gig Patriot Class 10 microSDhc card. I created a ext. partition for DT A2SD of 2 gig and converted it to EXT3.
I have installed a few different roms and played around with A2SD enough so that I finally got comfortable with it and picked out a ROM to really take some time to set up right.
Now for some reason my 2 gig part only shows as a 387 mb. partition with only 52 mb. available.
I've tried wiping the partition, mounted and unmounted - I've tried running the fix ext partition option in AmonRA 2.3
I've done a complete factory reset - wiped everything numerous times and I still only have a 13.9 gb. and a 387 gb. partition.
Can anyone help me to get this fixed????
Thank You so much for taking the time to read my dilemma.
Jack
Hmm.. I don't know much about app2sd, but you could try creating a new partition table for the card in gpart or something like that.
Jack
You flashed one of the ginger sense ports huh?
it's probably your sd card. I also bought one of those patriot cards on amazon because it was super cheap and (at the time) had great reviews. Now, not so much. The cards apparently are not compatible with cell phones. It is a known issue that the company has addressed on their website. Check out the reviews on amazon now, nobodys card has lasted more than a few months. I got just about two months out of mine before it died.
last weekend best buy had a sale on pny 16gb class 10s for about 35 bucks. I don't know if it's still going on or not but you should check those out instead
hrmmm....alost 12 months and no issues with mine....guess i am lucky!!!! you guys should send me your crapped out cards
wait you know what....i think mine is pny ....not patriot
