Well, you shouldn't have an issue activating it...I wouldn't worry about removing root.Hello i just got a HTC Evo 4G used and is rooted. Is there away to get the phn back to stock and removing the root. I wanna get it connected and idk if there gona let me connect it cuz is rooted.
TIA.
Do you know what rom is on it?Nice nice thanks guys.
Well can u guys guide me so i can install the ROM or somethinf?
What does "ported" sense rom mean....(I'm still learning)Make sure it's not a ported sense rom otherwise they won't be able to update prl and profile update. MikG would be just fine to activate a rooted phone.
What does "ported" sense rom mean....(I'm still learning)![]()
menu/settings/about phone..should be listed in there somewhere, perhaps under mod? version or build number..
Or if you need a rom, we can provide that man!!!! Some awesome sense roms out there, namely MikG v3.11!!!!!
o.k....I know you bought the phone rooted, are you familiar with flashing, booting into recovery or hboot etc, nandroid backups etc?Build number...myns warm twopointtwo software numver 3.70.651.1
If so, we'll probably guide you to a good recovery, sense rom etc.
Lets try not to through out to much techno talk all this can be extremely intimidating for the beginner. First find out what the OP does know.
What is your technical experties on a scale of 1 - 5
5 being OH YEAH I'M A GOD
1 being um the calculator is still absolutely terrifying to me.
Then we can go from there
I believe myns warm 2.2 is a sense rom...I would need confirmation of this, if it is cool to use as is, to activate your phone. If you would like a different rom, we'll provide links....Haha i think i might say a 3-4? :b
I have a rooted ZTE WARP...i have changed my nandroid a couple of times and changed ROMS also lol...i dnt really knw that much. I just knw a little lol.
Well can someone help me get that ROM the mikeg >.<? And how to install it...i dnt actually know alot about this phn lol.
Well, heres a link to the rom...use the full wipe version:
MikG v3.11 [3/9/2012]
Here's a link on how to flash it:..post # 3..skip step 4
Can we flash over the old ROM?
but first, I think we need to find out what recovery you currently have and perhaps upgrade it...am I right guys?
Simply reboot into your recovery. It should say in the bottom left corner what recovery it is.
(If you don't know how to get to recovery... pull out the battery, put it back in, and hold power+volume down to get to hboot. You should be able to select recovery from here)
o.k...we need to change that to a new, different recovery, CWM is buggy and doesn't wipe very well.CWM recovery...v3.0.0.5?
I will link to you Amon ra or the smelkus recovery I use.
Do you remember if you have s-off? (it will say this in your bootloader screen, at the top...if it is s-off then I can give you the PC36IMG file for the recovery)
