Ok, Fridays Q & A....
Made a liveCD. Rebooted pc and doing all that jazz. Now to download and extract files. Can I do that while running the liveCD? Do I need to dl those files PRIOR to running liveCD? And, am I dl'ing Linux or Windows version?
Thanks in advance, again.![]()
DirtyRacun has a Windows version (supported on 32-bit). I've run it several timesThe new s-off methods only work in Linux.
In the other thread, we have a pointer to the Ubuntu Linux download and they say how to run from cd. You can also do it from a USB stick.
You use either to boot into Linux instead of Windows.
See if you can get comfortable with that part first, no shame if you can't. You'll want to play with that and get group advice here first.
Then, it's a matter of downloading and following poor instructions. Sorry, that's on them, but there are folks to help.
.DirtyRacun has a Windows version (supported on 32-bit). I've run it several times.
I think only 7 32-bit is fully supported by Team Unlimited, but many have had success on XP (even some with 64-bit). If you have the proper drivers installed, there's no reason it shouldn't work. But you won't be able to get support from the official team on their channel if you have issues.Vista 32bit?
wow, where did I read that they weren't going to have a windows version because there were some sorts of issues with how it handled usb????
Edit: well, I'll be! there it is, right in our guide and their guide too! Old timers disease has struck again!![]()
That was the ticket. Now that my pc is booted to ubuntu, I dl'd the first group of files. I selected to dl and extract to the home/default folder. I also dl'd a terminal app as I was unable to locate a stock terminal. Im pretty much lost and out of f-bombs at this point.
Here's where I'm at.....
liveCD up and running.
Terminal downloaded and installed.
I can open Terminal and type commands.
I dl the first file listed to be dl'd.
Where do I extract and save it?
You extract anywhere you want to, just make sure you note what folder it is in.
For me, I made a new folder called "racun" and dumped all the necessary files in there.
You'll have to navigate to this folder in the terminal. In order to find the exact directory path, right click on the folder and look at the properties. It will be something like home/Ubuntu/racun*
*or whatever folder you extract to
EDIT: you navigate to that folder in terminal by typing cd home/uBuntu/*
where * is your folder name. Be sure to double-check the path of the folder though (by the right-clicking on it and viewing properties). Once you've navigated to that folder in your terminal, you should be able to carry out the instructions in the guide.
