now what? i guess i need to install TWRP now so I can go flash the ruu/radio stuff.
Yes? No?
just tried to get twrp through goo manager. i get the little red triangle when trying to go bootloader then to recovery. it will not go into recovery via goo manager.
it wont flash from bootloader or through goo.
i get an error when trying to flash through cmd that says 'fastboot' is not recognized as an internal or external command.
i was on hboot 1.15.
OK - as usual I dove right in and with some stops and starts along the way got to step 11 but could not get the htcdev site to accept the token. I tried several times but i kept getting a 404 error page your looking for doesn't exist
I had to.copy and paste one line at a time. Are you generating a code to send to HTCOK - as usual I dove right in and with some stops and starts along the way got to step 11 but could not get the htcdev site to accept the token. I tried several times but i kept getting a 404 error page your looking for doesn't exist
I was getting fastboot error when trying to flash via bootloader.i understand that, but now that you have s-off you can change your hboot so that you can use fastboot commands if you want to. it is not necessary. just throwing out some options. like rxpert said you can flash the twrp recovery via bootloader.
