I had this problem because I updated without my goldcard in. Thought I'd bricked the b@stard!!!! I was thinking about what excuse I was going to use to make a claim on my insurance!!!! Anyway, this is how I got it sorted.
If it has any relevance, my phone is unbranded, T-Mobile sim-locked.
1. download this :
http://liveimage.htc.com/OTA_Bravo_Froyo_HTC_WWE_2.09.405.8-1.21.405.2_release4dua3bcrut4wrv30.zip
2. When the download has finished, rename it to update.zip (be sure not to end up renaming it update.zip.zip !!!)
3. Copy the file to the root of your goldcard.
4. I removed the sim card, although I don't know if you have to do this.
5. Turn off your phone & turn back on with the down volume key pressed.
6. Navigate to "RECOVERY" using the volume key. Tap the power button to select.
7. Your phone will enter recovery (your phone will show a red triangle on a black screen) press and hold 'Volume Up' then tap 'Power.
8. Your device should now be at the 'recovery' screen. Select the 'wipe data/factory reset' option
***** You will loose ALL your data, but hey, at least you should get your phone back *****.
9. Select "Apply sdcard:update.zip" Your phone should then go though the update.
10. I can't remember if it will automatically reboot. If not select "Reboot" in the recovery menu.
I hope this helps some of you out.
Thanks go to several sources including Modaco & this site without which I wouldn't have been able to scrabble some sort of recovery.
