Im pretty sure it is....sounds very easy but for some reason its NOT WORKING..... its My PC is NOT ALLOWING ME ACCESS TO THE SDCARD and at times NOT EVEN SHOWING ON MY PC(WINDOWS7, If that even matters).
wats better cm7 or 2.2 offical wats faster and stable
it looks like evrybody moved to 2.2 offical so i ask
so y go to the new update from metro then
y all going to new update then nuttmeg did u go
bottom far right hard keywhat's the "End key".
thanks
Thanx..... it moved a little further but its still "stuck" now it says android on my screen.... By the way, do u know how long this "process" is suppose to take?
after you run the metro recovery file you phone should have rebooted and should have been back to 2.1 like when you first bought it.
well now I know for sure.... my phone is sick and on its last leg because it didn't do that..... well it acted like it was all good but then it...... well its just stuck on ANDROID with black back ground
just follow these step and it will put you back at 2.1, than you can retry putting 2.2 back on there.
Thanks. For some reason, it decided to work right this morning. I got it flashed to 2.2, and it works great now.
So can the metro version of 2.2 be tweaked for Cricket? Us Cricket users get no love, lol
what are the steps to update cm7 to latest build, CM7-Ascend-05212011? From your outstanding guide, I was able to install build 05142011. Thanks so much. Do I go through all the steps again, or is there a quicker way?
Welcome to the forum! We like new people here, so we hope you stick around! Glad to hear the update is working out for you.Been waitin a long time for this to come... And finally installed Froyo 2.2.2 and its working jst fine on my fone. Havent had any problems with it yet.... So far its goin great and its better than 2.1
de-bloated its even betterBeen waitin a long time for this to come... And finally installed Froyo 2.2.2 and its working jst fine on my fone. Havent had any problems with it yet.... So far its goin great and its better than 2.1
Is there a way to upgrade froyo 2.2-2.2 via heuawei ascend without a wifi connection? Also, this is my first post. This forum is awesome and very detailed in information. Thanks alot for the help I have had in the past. You guys rock!![]()
if you download it from the metro website and extract it to your sdcard, cause with 1x data trying to download that big update, will not work.
