PlayfulGod
Extreme Android User
to remove bloat use Root Explorer.
I'd make a backup b4 ya tried it. Its recommended to always wipe b4 flashing. With that said, I have done it many times with no issues.I have CM7 installed but I have noticed there is a new build out by playfullgod my question is do I have to go through all the steps like I did when I first installed cm7 or can I just go into CWM and install zip from sd and choice the playfulgods version?
yup those will do unless you're on a very old build currently.wipe data/ factory reset
wipe cache
advanced
wipe dalvik cache
so just do these 3 steps than i should be good to go with the update
i already have a good backup from just to hours ago
yesI'm sorry do I have to do gapps again![]()
Barcode scanners have never worked with Cm7-Ascend.I upgraded my cricket ascend to the cm7 (Build 06182011) and barcode scanning apps like shopsavvy etc will lockup the camera and I have to reboot to get it working again. Anyone know why?
I think it may have something to do with it trying to autofocus but I'm not sure
yes
do they work with CM6? also does Netflix work with CM6
not positive but I think the one from the market will work now too.netflix works with both cm6/7 but you might want to get the version from xda site.
tats basically the gist of it, it needs proper libs for it and none have been coded for 2.3 on the ascend. And unless someone that knows C++, we'll prolly never see it.Anyone know why specifically the barcode scanners don't work? One thing I noticed on an app called fooducate the camera was working until I hit autofocus then it froze. Maybe the OS is reporting it has autofocus so apps that have autofocus (like barcode scanning apps that benefit from it) start trying to use it and in turn freeze since the ascend doesn't have autofocus? I'm just guessing lol
check the cm7 thread then, isaac posted earlier stating what file it wasWell, I am learning C++ and it sounds like an interesting challenge![]()
Netflix does not use flash they used to a few years ago they switched to Silverlight by Microsoft. which works a lot better than flash for streaming movies and TV shows.Thought you needed flash for netflix.... Did I miss something?
