Root Often imitated,nevr duplicated,rubix focused 1.8.6
gmenfan83
Android Expert
i hope its i post this here ...just sharing what i found ...no credit goes to me as i am not a dev in this ....credit goes to Drod and the others mentioned here.
Update for 1.8.9 and 1.9.3 changelogs and dowloads:http://www.droidforums.net/forum/drod2169-x/99143-rubix-focused-1-8-9-1-9-3-a.html
Original post link:http://www.droidforums.net/forum/dr...mitated-never-duplicated-focused-1-8-6-a.html
Rom review:http://www.gizmoninja.com/2010/10/1...oms-updated-11162010-droid-x-aospvanilla-rom/
Often imitated, never duplicated! Focused 1.8.6
PLEASE READ THE FAQ BEFORE POSTING A QUESTION!!! Thank you
Want a review about the rom? Good indicator of if its your type or not? Check out the article that Blair at wjd designs wrote!
Droid X ROM Review, rubiX ROMs! Updated 11/01/2010 Droid X AOSP/Vanilla ROM! | Gizmo Ninja
I'd like to thank everyone that helped me and answered all my nonsense questions. AngDroid, Matt4542, BGill55, Wayne at WJD Designs, JsinLegacy, JRummy(especially) helped me a lot getting this ready, it wouldn't of been done without them!
Special Big thanks to Rainabba from Alldroid for helping me with this! He will be making something very big very possible very soon that will be incorporated into this rom the second I get it
**First 2.2.1 Droid X rom
Change Log from 1.6
Added reboot option to power menu
Security Features for my benefit
Various code cleaning and fixing
Couple of bug fixes
Upgraded to 2.2.1 Drivers
Framework better suits Generic (Lock screen tab placement, text placement)
Tweaks tweaked
More Blur removed than ever before
Added 3G HotSpot app
Home screen memory fix (credit to Beesley)
App Widget Picker included (Can't remember who made this, anyone know?)
Music Mod instead of Source Music app (Credit to Eliot Stocker)
Added Car Home back since it was removed from market
This rom is smoother, faster, stronger than ever before. You all will NOT be disappointed.
RELEASE NOTES:
Made from my own base
All apps Deodexed, Optimized, Zipaligned by Me
De-Blurred COMPLETELY
Build.Prop Tweaks (credit to Beesley)
All AOSP apps compiled 11/10/2010
ADW Launcher
3D Gallery
WORKING PHONE INCOMING CALL SLIDERS! (Credit to me and AngDroid)
Bloatware Removed
140+ MB Free in System at install!
Certain Market apps removed (Download from market)
Speed and Battery tweaks (Credit to me)
Internal Memory Manager raised to give better stability, battery life, and performance.
Syscontl.Conf tweaks (Credit to me/Pete)
Zipalign Apks script. My original intent was to run this on boot, but it causes problems with certain themes, so RUN THIS AT YOUR OWN RISK!!!! type Zipalign_apks in terminal emulator to run (Credit to Pete)
Updated BusyBox (Credit to JRummy)
Various bug fixes from Fission 1.0/rubiX 0.5
FaceBook now syncs to contacts! Sign in through FaceBook app!
AMAZING NEW AND UPDATED Boot animation credit to WJD Designs!
Battery percentage by the 10's, ACCURATE (images and fix credit to kejar31 since his coding rules and mine causes boot loops )
Rounded corners in the status bar (Credit to Cyanogen team)
Transparent Notification Pulldown
Undervolt optional, to use my undervolt settings, run lowvolt.sh in terminal emulator
Overclock Script! Credit to JRummy for the awesome script. To access, just run:
su
cpu.sh
in terminal emulator, and follow instructions from there.
BETA:
Auto boot strap on every FULL boot of the system. This is beta, and will be tweaked within the next few days as I adjust and fix it, and will be uploaded either as 1.8.7 or a patch.
Install Instructions:
Download rubiXFocused1.8.6.zip
Move to root of SD Card
Reboot to Clockwork Recovery
Wipe Data/Cache
Install Zip From SD Card
Select rubiXFocused1.8.6.zip
Install
Reboot
Enjoy
Please note, this has ZERO blur, except for settings, which isn't even blurry. Please do not ask me to add back in blur features, that's not the point of this rom, nor can I support ANY blur features that are not already in here.
Download:
http://bit.ly/ayMYRl
Mirror: Thanks Matt 4542!!!
http://bit.ly/cwqEoI
If you like my work, please consider clicking me to send me some red bulls
https://www.paypal.com/cgi-bin/websc...=TYYWQBR78DW7U
__________________
Follow me on twitter! @Drod2169
Check out my Droid X Roms:
Drod2169 - X - Droid Forum - Verizon Droid & the Motorola Droid Forum
I will wait to install when I'm off work and at home ....I saw the post this morning and am itching to flash it but don't want to f up while I'm out and about lol
Time to try something new. Downloading and backing up now.
Edit to add: Everything runs great. I got my theme converted. The only problem I have is I can't change any xml without the browser, market, drocap, and a few other apps FC. I will have to keep working on that so I can release this for rubiX. I may submit my black bar for testing though.
CAP2010112122411.jpgoverlay.jpgCAP201011212241.jpgCAP201011212240.jpgCAP2010112122421.jpgCAP2010112122331.jpg
Another great RubiX ROM, they just keep getting better and better. I was coming from 1.6 so I thought I would try without wiping the data and so far have had no issues and it is up and running great. I went ahead and got Quadrant scores on this (after about an hour after a reboot), base was right at 1,400, I applied my Overclocking after that and it was 1,700. These are just a touch better than what I was seeing on 1.6.
Great work again on this one.
Is the 1.8.6 still compatible with sinful green theme? I would assume so but ive only been doin this stuff for a week and dont want to mess anything up.
Hey all... anyone try this with black glass theme?
Im already running that, and am ready to try a better rom to compliment it.
SMS
SMS
I highly reccomend this rom although I have yet to flash since I'm at work ....I have used other versions of rubix and am a fan!.....once you flash this you will lose tour black glass look since the rom replaces it but I believe you can throw that back over the rom if that's the look you want or you can try others
Hey man....just a FYI...when u copied and pasted the info from original post it lost the link to the ROM Review...here it is so u can add it :)
Droid X ROM Review, rubiX ROMs! Updated 11/16/2010 Droid X AOSP/Vanilla ROM! | Gizmo Ninja
All I had to do is wipe catch coming from 1.6 works great its way more stable and a bit quicker too. I also love the reboot option in the power menu its legit! Idk if its new but the zipalign command is super cool also. I have this with sephtins blackbar mod curved and lcd density at 210 and its super slick stable and fast. Overclocking seems way more stable also.
Am I the only person that can't find these apps?
"Added reboot option to power menu
Added Car Home back since it was removed from market"
I tried the Apex rom first but it kept crashing, Then went to rubix 1.6 which was stable. now Im on 1.8.6 and its great.
After a Day of runig and leaving it overnigt my Quadreant score is 1376.
i probably wont overclock as its already plenty fast.
this ROM Rocks !
Can anyone tell me if the black keyboard mod will work for this or if anyone has tried it yet? I was talking about the one WJD made. Unless there is another that is compatible with this rom then please lmk, thanks..
I have seen where others on other forums are having trouble with other keyboards ..the update keyboard files in the folder this rom puts on your SD card are not working either....sephtin is said to be looking for a fix to this so hopefully soon but you can try it out and see if it works ....just make sure you have a backup handy
Questions guys, my battery life today has been terrible since upgrading to 1.8.6. Down to 40% an hour before lunch. It was never a problem with 1.6. Is anybody else having that problem or was today just a fluke?
GMB
GMB
i'm almost at 48 hours and at 30%. I mostly use music, browser, twitter apps.
GMB
i am reading the other forum and apparently some people may be having poor batt life due to the fact that for some reason drods sysctl.conf tweaks are not applying .....this may just be the cause ....in any event he is aware and there is said to be working on a possible patch....i have seen mixed reviews on the batt life and again i dont know if this is the main cause but maybe
