well i tried installing the zip directly to my phone and it say download unsuccessful! "Cannot download. The content is not supported on this phone."
You are rooted right?
1.try deleting the gmail app then redownload and set up....also make sure you have data push enabled in your settings and your fetch schedule turned on also in settingsLoving this ROM but had a few questions.
1. My Gmail won't automatically show up even though I have sync turned on (works fine for work email). I can only get it by manually syncing in the Gmail app. Thoughts?
2. For some reason I can't find the power control widget I used to have that is completely transparent. I've only been able to find one that is transparent but still has the colored bottom bars. (not ROM related - I know)
3. No FM Radio app any more. I gather that's a blur related issue and it sounds like it will never work on a blurless ROM. Just wanted to confirm.
Thanks peoples.
why i cant play music on rubix 1.8.6 or 1.8.9? it give me a error type not supported! please help
