Shotlimesalt
ROM: LiquidSmooth
Wallpaper/photo: http://i.imgur.com/qEYxy.jpg
(actually taken from my old Samsung Captivate)
Battery/clock: Minimalistic Text
Ah, this is what I was wondering about. You are not running Stock ROM, which explains the color change in the Notification bar. I figured everything else out but that.Currently using aokp m5 rom to modify nav buttons
Question: I just flashed AOKP cause I saw that you managed to get rid of the status bar or make it transparent, how did you do that?
Q2: Is your status bar still there if you swipe down in that area or is it gone all together? When I try to make it transparent it doesn't look right when I open apps, it just appears white and it looks ugly.
Q3: Does it make the dimensions bigger when you remove the persistent Google Search Bar with AOKP? Cause thats something I'd like to do as well and can't seem to pull it off. I disabled google search on my phone to make it go away but I dont want that. I use google search I just dont find it necessary to have on every screen when I have the button on the Nav bar.
Sorry for so many questions.I'm a new rooter and a frustrated one at that lol. When I try and look for this info I just see stuff from months ago and wasn't sure if there was an update that makes this possible with AOKP?
Q1: You change the setting in the launcher to hide the statusbar. Since you flashed AOKP, it comes with Nova Launcher by default. Within the Nova settings, there an option in 'Look and Feel' to hide the notification bar.
Q2: Now that I mentioned Nova launcher, I'm actually using a different launcher that provides a bit more features. The launcher I'm using is Apex Launcher: https://play.google.com/store/apps/details?id=com.anddoes.launcher Not only can I hide the statusbar, but I can use gestures as well intiate an action. In this case, I swipe down on the home screen to drop down the notification drawer.
Q3: Removing the persistent search bar does create more space, but increasing the grid size will give you even more space to layout more icons and widgets. This is an option that's available within the launcher settings. In my current setup, I have the grid set at 5x7.
Congrats to successfully rooting your phone and flashing AOKP. Play around with the launcher settings, as I think it's the first step to customizing your home screen.
How did you manage to create the custom folder shortcut to show just the star icon without creating the typical folder view (such as "stacked," etc.)?Here's my latest...
Black wallpaper
Bobclock D3 - hours gray to match soft keys, minutes ICS blue
Beautiful Weather 1x1 - Crystalx weather skin
Circle Battery (1x1) - color matched to ICS blue / gray
Custom Folder shortcut to most used apps (star from Metro Station icons)
Smooth Calendar widget - text color matched to ICS blue (today) / gray (future events)
Drawer icons - Metro Station Icons - color matched to ICS gray
Nova Launcher
My apologies...figured it out and answered my own question!How did you manage to create the custom folder shortcut to show just the star icon without creating the typical folder view (such as "stacked," etc.)?
So much so, that I had to post my blue paper!
Mind sharing that wallpaper? Looks awesome
Not at all. Included a few more like it as I'm on a nature/scenery kick lately. I've edited these walls (wallbase iirc) myself making them more vivid/saturated for our super duper HD amoled screens![]()
Damn! thanks a lot. It seems you and me like the same type of wallpapers. all of them are awesome! Thanks a lot
Yessir, and thanks. Figured I'd finally make my way back to androidforums. This thread needs some more shots.
Some others since I've had the Nex,
Will deff be around here again
