kracked dude
Member
Thanks! Go through the steps that I posted and see if it makes sense. Even if it isn't the same as how you did it, I feel what I posted is a pretty logical progression. The question is if it will work or is there a better way.
Kinda....I don't remember doing the nanadroid of the sd-ext tho....
I'm busy at work and don't want to try to post something that I'm not sure of and make a mistake![]()
This is what I think I did to my best recollection:
Power off the phone.
Take the old sd card out.
Put the new sd card in.
Boot into recovery and partition your new card like you did with the old one.
Power down phone.
Remove the new, now partitioned card.
Using the computer, transfer contents of old card to new card.
(Windows will not see the partition but the contents will move over)
Put the new card in phone.
Boot up the phone.
Using terminal emulator, type:
"su" (without the " " marks)
"a2sd reinstall"
"exit"
Profit!
Now before you do that, I really want to find my thread about this, when I did it.
I believe it was in the thread about Decks Reloaded...
I can look there later tonight as I have to leave work.
Edit: @biker---I think he is wanting to upgrade his card, not his rom![]()
Yes it will.Thanks.
If you boot up a phone which originally had a2sd and now the card doesn't have it wouldn't that break all the apps.
Thinking about that on my ride home (I do alot of thinking whilst I driveThat's why I'm suggesting to nandroid backup the sd-ext and restore it before booting up.. This should also negate the need to use Terminal Emulator to reinstall a2sd.
) and that does seem doable
Yes, you could, but I guess I like doing it from the computer....Also, would I be able to use USB toggle to move the files back into the SD card from the PC?
Again this is all theoretically and may not be correct in real life.
Yes that sounds like my original post!Yes it will.
Thinking about that on my ride home (I do alot of thinking whilst I drive) and that does seem doable
So let's review yours and my thinking here:
1. make a sd-ext nandroid.
2. Power down phone and pull old card.
2a. Put contents of old card onto computer.
3. Put new card into phone.
4. Boot into recovery and partition new card.
5. Mount card with USB toggle (still in recovery)
6. Transfer contents from old sd card to new card.
7. Unmount phone (usb toggle)
8. Restore the sd-ext.
9. Reboot phone.
Sound about right?![]()
Actually now that you mention it I just remembered I can also do it straight from my computer since I just got a new USB card reader to replace my broken one. But still I might do it via USB toggle.
What about my old card? I would like to restore it to original factory condition... Can I do that with the partition card option in recovery?
I believe so, yes. It should wipe the partitions.![]()
Sorry, had to take care of some stuffAnd what do I set for swap?
I think 0 for swap.
Scratch that...I just read the guide...set it at 32.
Swap is, in short, virtual RAM. With swap, a small portion of the hard drive is set aside and used like RAM. The computer will attempt to keep as much information as possible in RAM until the RAM is full. At that point, the computer will begin moving inactive blocks of memory (called pages) to the hard disk, freeing up RAM for active processes. If one of the pages on the hard disk needs to be accessed again, it will be moved back into RAM, and a different inactive page in RAM will be moved onto the hard disk ('swapped'). The trade off is disks and SD cards are considerably slower than physical RAM, so when something needs to be swapped, there is a noticeable performance hit.
Unlike traditional swap, Android's Memory Manager kills inactive processes to free up memory. Android signals to the process, then the process will usually write out a small bit of specific information about its state (for example, Google Maps may write out the map view coordinates; Browser might write the URL of the page being viewed) and then the process exits. When you next access that application, it is restarted: the application is loaded from storage, and retrieves the state information that it saved when it last closed. In some applications, this makes it seem as if the application never closed at all. This is not much different from traditional swap, except that Android apps are specially programed to write out very specific information, making Android's Memory Manager more efficient that swap.
Just finished upgrading my SD card.
Everything went according to plan! Thanks again
Nice!! Your theory was correct then. Sweet!
Just following what seems logical in my brain.
So I went to TE and did a2sd check and it looks good. While there is saw something called zip align so that bring me to a new question, what is it and when would I use it?
TYVM
so here we go with an informative link or 2
Final update
I have her keep entering in her email and password until it finally worked. Dunno why the other times it want working.
But for future reference, I'm wondering if the following procedure will work. Go to recovery make nandroid backup and restoring the backup. Will that work?
