goop factory
I was gonna post the link to the su zip but i guess i'm not qualified to post links
But now you can.
whatever :eviltongue:ummmmmmm........you mean robot![]()
yeah to be honest i would not worry about su as long as it gives you root permission.......all is good.
and why flash su and stay on stock, when there are so many better roms out there? htc and sprint did a horrible injustice in designing the stock rom.
mikg is sooooooo much better then stock......it is what they should have released.
plus i'm not a big fan of sense......pure android (aosp roms) is the way to go in my opinion......but that is up to you.
Yeah I've been reading up on ocn and capn and i'm getting an idea they have a pretty good grasp on what's going on. one of the reasons why i decided to be active in this forum as compared to the many i've just browsed. was hoping to get some clear answers.
ok when you say, "i would not worry about su as long as it gives me root permissions"=meaning once flashed if theres no problems why worry about something that's not broke yet? well messing with computers for so long i always try to think a couple steps ahead and see if i'm heading in the right direction or worse, off the fing cliff, before making any moves or action. it's easier to back track if you didn't track at all. I guess.
I'm gonna try out this mikg rom...once i get done blabbing. So I went back to the instructions and read about flashing the rom, which mike stony said that most roms have the su code already cooked in it...so i wont even mess with flashing it i guess or should i flash it just to make sure all is good?
oh and my other ? was about the superwipe .zip is that pretty much the same thing that htcdev's site talks about wiping out the cache and temp files after flashing the rom so it wont potentially get stuck in a boot loop? Is it basically a batch or script or whatever that does that for us?
oh yea the download link for the su zip is broke...as i told mike stony, not a big deal, I found it at Superuser downloads | /superuser in case anyone else might ask. Many thank you's and I'm gonna give this mikg a try and see how i like it
So I took the jump to decks reloaded!
Now how do I get a2sd working? Is it a separate zip I need to flash? I have terminal emulater and the a2sd commands aren't working.
Also the market isn't updating to play store.
I tried
a2sd check
a2sd reinstall
Both give me a2sd not found
Is there a way to check if the SD-ext is being mounted?
[ ] Apps2SD is launching...
__ _____
|__/ | Darktremor Apps2SD 2.7.5.2 (2010-09-30)
[ ] GetProp Command = /system/bin/toolbox getprop
[ ] SetProp Command = /system/bin/toolbox setprop
[ ] Mount Point = /system/sd
[ ] Creating /cache/dc
[ ] Symlinking /cache/dalvik-cache to /data/dalvik-cache
[ ] Starting Apps2SD Check Program.
[ ] Checking for ext partition
[X] Ext partition found, but not mounted.
Your rom may not be setup to run Apps2SD.
Check with your rom developer if the boot image
is programmed to run Apps2SD.
Your partition may be using an EXT4 partition,
but your rom may not support EXT4. Repartition
your SD card to use EXT2 or EXT3.
