Asurion doesnt look for watermarks? They'll still replace it?
yep:thumbup:
Alright, so here's the deal. I HATE getting into missions. Whenever I get myself into a mission mode, I'm screwed until I finish. This has now become a mission. I'm trying to just say screw it and just go HTCdev, but I want to make sure that I've tried everything I could before dropping tacoroot.
Here's my attempt. Does anyone see anything wrong? It's STILL stopping me at the image. "flash_image" and "mtd-eng.img" (yes, my extensions are shown on my pc) are both copied onto the ROOT of my card via evo. In the folder I'm using cmd thru, "droid", I have "adb.exe", "adbwinapi.dll", "fastboot.exe", "tacoroot.sh"
If you have TEP, then you don't need to worry about the watermark, if your device is out of warranty and needs to be replaced. Asurion doesn't care if your device is watermarked, rooted or whatever. If it breaks, you'll still have to pay the deductible, and they'll send you a "comparable replacement."
I'm not worried about Asurion, I'm worried about the repair side through Sprint. I don't want something to happen to the phone and not be able to have them replace it because HTC told them I'm rooted and use the unlock tool.
+1are you sure that you have extracted the image file? sorry my icons look different then yours for the flash image file when extracted.
+1
The flash_image you're showing there hasn't been extracted - it's still in the zip file (i.e. that's why it shows with the WinRAR icon).
That looks right. And when you run the commands, you set the device back to Charge only mode, correct?haha i wish that was it.... thats just the original zip file... i have them extracted in the sdcard. Take a look
hey guys same problem here but the phone keeps looping splash screen so how do i set to charge only or exit this and start over im trying to push flash_image as well same issue
i just dont want to screw something up by turning off phone in this mode
the if you are on step 12, proceed to 13:
adb shell /data/local/tacoroot.sh --undo
this will bring your phone to the stable state.
you should have had it in charge only to begin with... its all in the step by step guide, its like one of the first things...
welcome to the forums!!!!!!!after a reset and sd wipe and setting charge only default worked fine i think the default was set to sync and causing boot loop
Only thing I can suggest is you can try re-downloading the flash_image file. I attached one in this thread. I know some people had trouble with corrupted downloads from the files over on themikmik.Yessir.
I just began my rooting today and now i'm stuck.
Nevermind, I believe I have figured it out. I just gave up to early.
step 2 How to get Recovery
here is a little more details on how to get a recovery onto your phone. there are several ways of doing it. you can use the fastboot command to install recovery or you can use the android flasher program and lastly there is the PC36IMG method. either way, it is pretty simple. i will leave the decision up to you.
various methids to install amon ra 2.3 recovery:
ADB command method
1.download amon ra 2.3 from here:
PC36IMG_RA_2.3.zip
2.extract the recovery.img file and place it in the android folder you created when unlocking your bootloader.
3.on your phone after you have unlocked your phone you should be in the bootloader menu screen, select the fastboot option
4.on your computer press and hold shift while right clicking the android folder.
5.select open command window here option (windows 7)
6.enter command:
Code:
fastboot flash recovery recovery.img
congrats!!!!!! you have just installed amon ra 2.3
OK so I am totally new to this and am actually proud that after 4 day's I have been able to unlock my phone using your HTC DEV method. So here is where I need help. I have not been able to get anything done but that. I am back into my phone and have tried all of your recovery methods you gave the android one all of them. I even went back to try the CaptainThrowback method and the TacoRoot one. The TacoRoot one keeps telling me it can't find my device and the Android one you have in the HTC Method just stays on please wait while your phone is flashed. WHAT DO I DO? All I want to really do is get the new Ice Cream Sandwich on my phone. Can you please please please help me?
Thank you in advance
Thank you for your response. So I slept on it and went back and followed the HTC Dev method and the adb command method for the recovery and this is what my little black screen said
C:\Android>fastboot flash recovery recovery.img
sending 'recovery' (3544 KB)...
OKAY [ 1.041s]
writing 'recovery'...
OKAY [ 1.373s]
finished. total time: 2.414s
C:\Android>
So I think that worked. Ok. so what do I do now? Sorry for all the questions. Also I had downloaded that titanium backup app and its telling me that it is not able to work because my phone is not rooted. What does that mean? That is probably a couple steps ahead though. Thank you for helping me get this done, I am so tired of using gingerbread and can't wait for ICS.
