Woohoooo! Rooted and ROM'd! Thanks for the great guide, ocnbrze! I can hold off on a new device for a while longer, now.![]()
NICE!!!!!!!!!!!!!!!!!
to go and get your flash on
and do not forget to make a nandroid backup.
I will add that into the guide. Been meaning to for a while, keep forgetting to do it.
[Revised] Rooting Gingerbread 2.3.5 Dummies Guide said:rooting your phone will wipe all data so make sure that you backup your info accordingly:
1.for cantacts make sure that you have them all saved under google. that way when you flash a new rom or even get a new android device, you can sign in to google and all of your contacts will sync to your phone.
2.if you want to backup your sms or even mms text messages then you can use SMS Backup & Restore and it will save them to your sd card.
3.for your apps data, you can use MyBackup Pro. this will pretty much back up everything for you.
welcome to the forums!!!!!!!!!!!!!!First off this is my first time to root i have tried some other guides and have had no luck (due to lack of information and poor quality videos) however i have gotten pretty far with this guide and i am very thankful. except for the fact that my phone is stuck in the reboot screen like where its says sprint and has flying squares and then ends in 4g it just keeps repeating it over and over again! i havnt tried to recover since this has happend bc the guide says it will eventually reboot. i am inbetween step 10 AND 11 on the taco guide!
please help!
jhi
so i read that it says my phone my not even boot and like i said above it isnt so i continued trying to use the guid and this is what i am getting
C:\Users\Jordan\Desktop\Android>adb shell
# cat /sdcard/flash_image > /data/flash_image
/sdcard/flash_image: No such file or directory
think it is bc my phone will not turn on ?
jhi
welcome to the forums!!!!!!!!!so i finally got the nerve to root.
I've read throught the guide a few good times and im still a little unclear on some minor details.
1. exactly where are the steps that i could possibly brick the phone(im going to use the HTCdev method), i wanna know so i can study them and really familiarize myself with what needs to go down
2. "9.you will need to copy the long block of text that is displayed
Right Click > Mark > highlight the block of text > Right click to copy
10.the first line you should highlight should be:
<<<<<Identifier Token Start>>>>>
and end with:
<<<<<Identifier Token End>>>>>
11.paste the text into the token field and then hit submit.
12.you will then get an email with the unlock key and commands to finish the process".......this part is kinda confusing. what do i have to enter? does it start with the arrows, or is it everything in between?
ex.
<<<<<Identifier Token Start>>>>>abc.ect<<<<<Identifier Token End>>>>>
or is it like this?
3. do i have to have usb debugging checked and when do i have it mounted as disk drive and when do i have it on charge only? through out what steps?
"first lets make sure that this guide is for you. before we do anything make sure that you have disbaled fastboot. on you phone go to settings>apps>uncheck the fastboot option at the bottom. next you will need to power off then press and hold power+vol down. this will take you to the bootloader screen.
1.if you have hboot 2.18 and it says locked at the top then this guide is for you. "
-->I can not even get to this part. I disabled fast boot as you said and now no matter what I can not get my phone to boot back up. Help please!
no my phone will not turn on at all. It has not indication lights either. If i plug it in to the usb cable it shows it there but it wont even go into the bootloader
Ok so I have gotten it to boot up but not in the bootloader. I am still, even after this scare of bricking my phone, willing to root it.
Has anyone ever had that same problem?
currently in the bootloader! Yea!
welcome to the forums!!!!!2.18 EVO 4g 2.3.5 < waiting on device >
that is actually normal. being that you are not rooted and are not allowed access to those commands.So I thought id give it another shot, and this time, im going over every slight detail...
When I begin tacoroot, and I boot into recovery, I wait for the red triangle/exclamation point and i press Vol +and- and power, I see a bit below the middle of the screen "E:Cant open /cache/recovery/command" in yellow font. I click power button to select reboot system.
Is that yellow error supposed to come up when tying to boot into recovery, or is this why i havent been able to get anywhere?
welcome to the forums!!!!!!!!!I followed all the steps, but when i entered the code I get this message:
We're sorry, but it appears your attempt to unlock the bootloader on this device has failed. This could be caused by several factors including simple errors in the entry of the unlock token, problems with your device, or a lack of manufacturer support for the unlocking process. Please see the specific error code listed below, and try again if necessary.
Error Code: Invalid Bootloader Token Length.
Error Reason: The submitted Token appears to be the wrong length and won\'t work.
I am quite sure I did everything properly...anyone know what the problem might be?? Thanks!
Thanks for the quick response! well it looks like the token I put in was put in correctly. Is there anything I might be forgetting to do to my phone first that would give me a different token? Is the token that I paste being generated from my phone? By the way-I'm using the official HTC method.
Eventually.It worked! I tried it again this morning and for whatever reason it all went through. Now aren't I supposed to be able to delete nascar and all that junk??
Bricking it is really hard to do, really. Just follow the guide step by step and u should be good to go.
it is now telling me in the command prompt that oem is not recognized as an internal or external command.
Any one know what I am doing wrong?
Thank you in advance!
welcome to the forums!!!!!!!!!!EVO 4G 2.3.5 with 2.18 and am getting <waiting on device > in command prompt when i copy and paste token, fast boot off, usdebugging on and never receiving the token
I'm trying taco root and when I do step 10
adb shell /data/local/tacoroot.sh --root
it says error: device not found
Am I supposed to do it while it's still green? Do I wait until it's red?
I've tried both.
