scrubbydutch
turns out my driver is outdated because it keeps telling me there is an issue with the device, need help getting and update driver
I believe I have the latest HTC sync. If nit you can go to HTC's website and get the latest HTC sync there. With HTC sync will come with the latest drivers.turns out my driver is outdated because it keeps telling me there is an issue with the device, need help getting and update driver
stay on stock
you will need the latest su(superapp) found here:
Superuser-3.0.7-efghi-signed.zip just flash that in recovery and you will have a rooted stock rom:
1.download and move the su file to the root of your sd card that means not in any folder. it just needs to be on your card.
2.go into recovery (power off, make sure fastboot is unabled, and then press and hold power+vol down)
3.select flash zip from sdcard
4.navigate to your su file by using the vol up and down button and select it with the power button.
5.once done, reboot. now you have a rooted stock rom
so when i am doing this it is telling me that it cannot complete action in recovery. The file is on my sd card but it is not unzipped because it wont let you. Am I missing a step...I am sure that i will go custom later, its all new so i thought i'd start off stock
Ok so do you have a custom recovery? What is extactly the error you are getting?
it says
"finding update package...
Opening update package...
e:cant open /sdcard/superuser-3.0.7-efghi-signed.zip
(bad)
Installation aborted
I would redownload it. sounds like you got a bad download.
i have redownloaded it twice once to the android folder and then transferred over then once direct to the sd card still the same error
do i have to flash a rom or can i continue on to the unrevoked portion of unlock?
you do not have to flash a rom, but i would highly recommend it. i would try mikg3.11 as it is way better then stock. plus it will have sprint's hotspot hacked and all of the bloatware removed.
not sure why you are having a hard time with the su file.
So drivers installed, going through all the hassle figured why not ask which Rom should I ? Ice cream 4.0.3 maybe ?
welcome to the forums!!!!!same issue with that rom, and now phone only opens it in bootloader screen and sd card is not accessible now, will need to take sd card out of phone and put into adapter later, right now its a good paper weight
welcome to the forums!!!!!!!!!I have the evo 2.3.5 hboot 2.18
how am i supposed to root my phone, the same way by using the hboot 2.16 one? or is there something different i need. i'm not quite sure what these # means lol but do they really matter when rooting?
I did the HTCdev method and flashed the MikG 3.11 ROM and i really, really like it! Thanks again, ocnbrze.
One problem I'm having that I haven't seen listed on this thread is an inconsistent ability to access SD card via PC through USB. I plug it in, it shows up in Windows Explorer as a Removable Disk, then disappears, or stays there but when I click on it it says to connect a device. Out of about six attempts today I finally got it to work once.
Any ideas what the problem might be or better yet, a solution? This never happened before rooting and ROMing, even once. Could be the card, I suppose, but it seems a strange coincidence.
Two different computers and two different cables, but it sounds like many options remain. Thanks, I'll check out the XDA link!
not too familiar with sh-32#.im trying to unroot my evo and it keeps giving me a accessdenied
C:\Android>adb shell
sh-3.2# cat /sdcard/flash_image > /data/flash_imag
cat /sdcard/flash_image > /data/flash_image
sh-3.2# chmod 755 /data/flash_image
Toolbox!
sh-3.2# /data/flash_image misc /sdcard/mtd-eng.img
sh: /data/flash_image: Permission denied
sh-3.2#
Hello, this is my first time rooting a phone. I have the HTC Evo 4g and used the HTCDev method. Everything went fine until I went to do step 3 where you flash the superuser file. I put it in the root of my sd card and pressed volume down + power and went to the boot screen. I went down and selected recovery and I got a black screen with a phone and a red triangle over it. Nothing happens after this. What did I do wrong!?
welcome to the forums!!!!!!!!!!!
that is because you still have a stock recovery which you do not have access to. you need to install a custom recovery. you need to do step #2 to get recovery onto your phone then you can flash the su file.
Thanks! I actually figured it out last night before I went to bed. I'm now fully rotted and trying to figure out how to use overclock.
