Root [Revised] Rooting Gingerbread 2.3.5 Dummies Guide
ok just to make sure, you are in the bootloader right? it should scan and then say "no image or wrong image" if it did not find the file. this is what you see, correct?
ok so i'm thinking then that something might be wrong with the card. so lets back up everything to the pc and then reformat the card in your phone. on your phone go to settings>storage>and erase sd card. this will reformat the card. now move the PC36IMG file back to the card. do not add your cards content just yet.
Ok. Listen I need to pick this up tomorrow..Sorry about this..Thanks for the help..
These guys will get your through it, Digital. They got me through rooting last week!
I hope so...If not I will throw my phone out the window in a heartbeat....I'm back btw....Anyone up to help me here finished what.. been started.
Edit: I did a backup of my sdcard and reformatted it..I upload the file onto the sdcard and did a hboot..Same problem...Any ideas on if its the memory or if my phone a piece of crap.
ok I got the adb what next..boss
o.k...go to the beginning of this guide and look for this:
1.download amon ra 2.3 from here:
PC36IMG_RA_2.3.zip
2.extract the file and then go into and move recovery.img file into the android folder you created when unlocking your bootloader.
3.on your phone after you have unlocked your phone you should be in the bootloader menu screen, select the fastboot option
4.on your computer press and hold shift while right clicking the android folder.
5.select open command window here option (windows 7)
6.enter command:
And download the .zip file and just follow the instructions.
Like I said, my replies may be delayed, for I am at work;)
That what I messed up there..I got the message about yes or no I skipped a freaking cmd code and I was like F****************** (you get the picture)..Anyway I got the option to say yes and no which one should I choice to unlock the bootloader.
Not sure where you are at, do you still have the .bin file in your android folder?
its unlocked now..Woot thanks guys..#1 all the way.
phew!!
Now back to the PC36IMG method for recovery if you desire, or the adb method....:D
Edit: got your p.m.'s btw...its all good...no worries
I did the recovery method..i don't know if its already into the phone...But I think that already done.Right.
Edit: Scratch the P.M's
Just follow those instructions listed to stay on stock if you desire.
You can always flash a custom rom later but custom roms such as Mikg are sweeeeeterrr!!!
First things first..I want to use my phone on a different carrier.. with the same number I have that I am using if its possible.I don't want to add another line to it and spend over $100 or so.
Edit: I downloaded the file and now I am puzzled here..What do I have to do next..I don't see the su file.
