Digital404
Member
Yes..I know what you proble are thinking (What a freaking moron here..How could a newbie be so dee dee dee at times)...I hope I get this thing right.
Nah, been there, done that...don't feel bad. I've overlooked things also.Yes..I know what you proble are thinking (What a freaking moron here..How could a newbie be so dee dee dee at times)...I hope I get this thing right.
Thats no problem now (you may need it later) because the 3 files you need to put into your Android folder (which you will create on your desktop) are in the guide....I have one problem though..I don't have no android sdk installed.
On the htc website, it wants you to install the sdk to get those files.
But ocn has conveneintly posted those files already...follow?
These 3 files should be put in your android folder
adb.exe
fastboot.exe
AdbWinApi.dll
Edit: just saw your edit...nice![]()
You're not a pain, I just like helping!Ok...It has the token start and token end how do I set that up..is it what at the sample or something different. Also the unlocked_code.bin how do I set that up aswell
Example: Identifier Token Start fastboot oem get_identifier_token Identifier token end
Sorry for been a pain in the rear.
Ok..I got the sdk running and its asking me to download the platform and tools..Which I am getting and error saying access denied..If someone has the .zip files I can DL and use them, That be great..On the other hand I haven't got to the part on ID token.
My machine sucks big time.
Do you have the java file and htc sync installed?Ok I got the files what next?...They in a android folder.
It's java, you'll see. no worriesThe java file is chromeinstall.6u27.exe...That no java more like browser.
o.k..the files in your android folder...you just put them there right? do not run them or anything, just put them there correct?Ok..Everything installed and done.
Now go to the website, create an account using your true email, and follow instructions 1-4, then let me know when you get done after step 4, as step 5 you have done just now. You need to skip step 5 and go to step 6, follow?Yeaper..What next Boss.
skip step 5, you've pre-done that already,...go to step 61-4 done onto 5 and up
did you put your android folder on your desktop?Done that and did 7 should I hit enter once I put in cd c:\android
C:\Users\Mike\Desktop\Android>
NIce!! moving right along..excellent.I did the second option I have the identifier token codes...What next. I have done step 9 and on 10 right at the moment.
