They've taught me a great deal...!!😴You guys are the best. Helped me through this a few days ago and now helping this guy. This forum rules.
Welcome and Congrats on rooting/flashing.!I rooted my phone last weekend using HTCdev method and flashed the MikG v3.11 [3/9/2012] rom. It was a lot easier than I thought it would be.
After rooting my battery life dropped to less than 5 hours. I have the SEIDIO 3500mAh battery and could get at least 17 to 18 hr of battery life before. So I was a little disappointed and surprised.
I tried again this Sunday. I restored the nandroid backup and followed the direction again. I did everything like I did the first time with the exception I left it unplugged from the computer. Once again it was really easy. The only difference is my battery life is now better than it was to begin with. It has been unplugged since about 9 am on Sunday now it after 9 on Monday and I still have 20% left on the battery.
The question I have does leaving in plugged into the computer affect anything. Apparently from my results it seems to affect the battery but does it affect anything else. I want to try other ROMS and just don't want to brick my phone for something as simple as not unplugging it.
Yeah, sometimes it takes a few days for the rom/kernel to settle in but his battery life was less than acceptable...5 hours? geez!My battery life was shortened the first couple of days after rooting last week. It's getting back to normal now.
Especially with a 3500mah battery....blah
uke:It was the same rom the only thing different was it was not plugged in.
Hello and welcome!Im having problems running htcdev.
Error Code: Invalid Bootloader Token Length.
Error Reason: The submitted Token appears to be the wrong length and won't work.
anyone seen this before?
It took me some getting used to when I first did it to "mark" it in the correct spot to copy, it.....I just tried it a couple more times. theres the same about of text. not sure what the problem is
okay I finally got it haha. ive got it flashed and everything. still tells me I dont have root access, Is there something else left to do?
youre the man! is there a certain custom rom you recommend?
I was wondering if the tacoroot method will work the same on Linux Ubuntu and terminal vs. Windows and command prompt? If not, it is not a big deal I can borrow my room mate's computer but I would like to use mine, which is Ubuntu Linux. Thank you!
