You need not get rid of the .zip....Just rename it PC36IMG.zip...dont add an extra .zip...windows will hide .zip extensions....
i need quick answershow do i put it on to the sd card
and how do i get rid of the .zip
look at the 2 posts above yoursi need quick answers
sorry to be annoying
when you plugged your phone into your computer, do you have an option that pops up on your phone to "mount as disk drive"?i did everything but when i drag it to the removeable disk it says:
Please insert disc into Removable Disc (G![]()
Did you download the correct .zip for your software version?now it tells me that the main version is older and then asks me to reboot device
doesnt ask me to update
I learned from the best! Thanks for guiding me and hovering around here guys.Stonys a machine!
As in, you tried both .zips? And you got the same error?it still wont let me
o.k..good,5.07.651
hmm..odd ..stand by a minute k?
No, he unlocked his bootloader with htcdev.Is he trying to downgrade? Sounds like the downgrade didnt work
look here for a similar situation
http://androidforums.com/evo-4g-all...bread-2-3-5-dummies-guide-21.html#post4336453
hmmm, good point...his bootloader may have picked up the first, wrong .zip...but then again, he would have gotten some kind of other error after renaming the correct .zip and trying to transfer that to sd card if one was already on there.No RX. He needs to use the 5.07 version. It is the one that the captain made to use with the latest version. Not sure why it is saying older version though.
Maybe the old pc36img file is still on the card?
how would i do that
how can i get it and delete it
NICE!!! Thats great...You are just about done!i did the fastboot method and worked thanks
