Root [ROM][4.0.4][BETA] CM9 for Virgin Mobile and Sprint 10/3/2013
And you left out the 1 person who got cm working.
I didn't mean anything by it. Phenom is THE MAN when it comes to this project. :beer: but I feel like with those contributing they all together can get it to the next level.
Don't blame me. Blame the pain meds
I talked a little with the Triumph guys. They edited/created (not sure which) a camarahal library to allow the CM7 kernel to work with CM9 on that device. Now, I don't think it would be a direct drop in replacement, but they have heavily commented the camerahal library which someone who know what they're doing may be able to use to help us with ours. Have a look at the Triumph All thing root thread, WIP Camera CM9. In there should be the reference to the dev tree.
^This!
If I wanted to attempt porting CM10.1 to our device, where would I start reading up on this stuff being completely new to this?
Anyone else notice that some of the framework images throughout the rom are low quality/blurry? Especially some of the stausbar notification icons
For those having problems with the SD Card. I think it has to do with the partitions. My Elite took the partition away and formatted the whole drive as Fat32. Repartitioning it using linux has now made the SD Card readable.
Wifi didnt work and mostly ever app kept closing and stopping
Try doing an entirely clean wipe in CWM. Factory/data wipe, cache partition, dalvik cache, format system, data, and cache. Try all that and re flash, also you might want to verify a good download, check md5 sums.
check md5 sums.
I didn't see an md5 sum posted anywhere, but here's the one from my download which is working perfectly - 24A613C2F965981BE56777A5F1B82A69
I haven't had any reboots or app crashes or anything. If your download matches that then you should be in good shape.
Oh..... right, my mistake. I just assumed there was one but I never looked..
.... Here's what I got on both the GApps and the Rom
What phone was it that's most like this one again? Are there any CM9 builds very similar to this one as well? I'm gonna start looking for generic camera fixes and try them all. :D
I think I'm getting close.
PHP:
01-23 10:58:41.301: I/CameraService(131): CameraService started (pid=131)
01-23 10:58:41.311: I/QualcommCameraHardware(131): getCameraInfo: IN
01-23 10:58:41.341: I/QualcommCameraHardware(131): getCameraInfo: loading libqcamera at 0xb000ead8
01-23 10:58:41.341: I/QualcommCameraHardware(131): getCameraInfo: numOfCameras = 1
01-23 10:58:41.341: I/QualcommCameraHardware(131): Camera sensor 0 info:
01-23 10:58:41.341: I/QualcommCameraHardware(131): camera_id: 0
01-23 10:58:41.341: I/QualcommCameraHardware(131): getCameraInfo: OUT
01-23 10:58:41.341: I/CameraHAL(131): camera_get_number_of_cameras: number:1
01-23 10:58:46.406: W/PackageManager(226): Package com.android.camera desires unavailable shared library com.google.android.media.effects; ignoring!
01-23 10:58:49.809: I/PackageParser(226): slide.cameraZoom: compat added android.permission.WRITE_EXTERNAL_STORAGE android.permission.READ_PHONE_STATE
01-23 10:58:54.583: W/PackageManager(226): Unknown permission android.permission.LOCATION in package com.kth.PuddingCamera
01-23 10:58:54.583: W/PackageManager(226): Not granting permission android.permission.INSTALL_PACKAGES to package com.kth.PuddingCamera (protectionLevel=3 flags=0x18be44)
01-23 10:58:54.583: W/PackageManager(226): Unknown permission android.permission.WRITE_OWNER_DATA in package com.kth.PuddingCamera
04-16 16:33:25.663: W/PackageManager(226): Unknown permission android.permission.LOCATION in package com.kth.PuddingCamera
04-16 16:33:25.663: W/PackageManager(226): Not granting permission android.permission.INSTALL_PACKAGES to package com.kth.PuddingCamera (protectionLevel=3 flags=0x18be44)
04-16 16:33:25.663: W/PackageManager(226): Unknown permission android.permission.WRITE_OWNER_DATA in package com.kth.PuddingCamera
04-16 16:33:37.040: I/ActivityManager(226): START {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.camera/.Camera bnds=[0,339][80,429]} from pid 433
04-16 16:33:37.130: I/ActivityManager(226): Start proc com.android.camera for activity com.android.camera/.Camera: pid=1208 uid=10010 gids={1006, 1015}
04-16 16:33:37.630: I/QualcommCameraHardware(131): Found a matching camera info for ID 0
04-16 16:33:37.630: I/QualcommCameraHardware(131): HAL_getCameraInfo: HAL_cameraInfo[i].sensor_mount_angle = 0
04-16 16:33:37.630: I/QualcommCameraHardware(131): HAL_getCameraInfo: It is Others
04-16 16:33:37.630: I/QualcommCameraHardware(131): HAL_getCameraInfo: before HAL_cameraInfo[i].sensor_mount_angle = 0
04-16 16:33:37.630: I/QualcommCameraHardware(131): HAL_getCameraInfo: before APP_ORIENTATION = 90
04-16 16:33:37.630: I/QualcommCameraHardware(131): HAL_getCameraInfo: after HAL_cameraInfo[i].sensor_mount_angle = 0
04-16 16:33:37.630: I/QualcommCameraHardware(131): HAL_getCameraInfo: after APP_ORIENTATION = 90
04-16 16:33:37.630: I/QualcommCameraHardware(131): HAL_getCameraInfo: orientation = 90
04-16 16:33:37.630: I/QualcommCameraHardware(131): HAL_getCameraInfo: modes supported = 5
04-16 16:33:37.630: I/CameraHAL(131): camera_get_camera_info: id:0 faceing:0 orientation: 5
04-16 16:33:37.630: V/CameraHolder(1208): open camera 0
04-16 16:33:37.630: I/CameraService(131): Opening camera 0
04-16 16:33:37.630: I/CameraHAL(131): camera_device open+++
04-16 16:33:37.630: I/QualcommCameraHardware(131): getCameraInfo: IN
04-16 16:33:37.670: I/QualcommCameraHardware(131): getCameraInfo: loading libqcamera at 0xb000ed08
04-16 16:33:37.670: I/QualcommCameraHardware(131): getCameraInfo: numOfCameras = 1
04-16 16:33:37.670: I/QualcommCameraHardware(131): Camera sensor 0 info:
04-16 16:33:37.670: I/QualcommCameraHardware(131): camera_id: 0
04-16 16:33:37.670: I/QualcommCameraHardware(131): getCameraInfo: OUT
04-16 16:33:37.670: I/CameraHAL(131): camera_get_number_of_cameras: number:1
04-16 16:33:37.670: I/QualcommCameraHardware(131): openCameraHardware: call createInstance
04-16 16:33:37.670: I/QualcommCameraHardware(131): openCameraHardware:Valid camera ID 0
04-16 16:33:37.670: I/QualcommCameraHardware(131): openCameraHardware:camera mode -44
04-16 16:33:37.670: E/QualcommCameraHardware(131): openCameraHardware:Invalid camera mode (-44) requested
04-16 16:33:37.670: E/CameraHAL(131): Couldn't create instance of CameraHal class
04-16 16:33:37.670: I/CameraHAL(131): camera_device_open--- fail rv -12
04-16 16:33:37.670: E/CameraService(131): Could not open camera 0: -12
04-16 16:33:37.670: I/CameraService(131): Destroying camera 0
04-16 16:33:37.670: E/CameraHolder(1208): fail to connect Camera
04-16 16:33:37.670: E/CameraHolder(1208): java.lang.RuntimeException: Fail to connect to camera service
04-16 16:33:37.670: E/CameraHolder(1208):     at android.hardware.Camera.native_setup(Native Method)
04-16 16:33:37.670: E/CameraHolder(1208):     at android.hardware.Camera.<init>(Camera.java:320)
04-16 16:33:37.670: E/CameraHolder(1208):     at android.hardware.Camera.open(Camera.java:280)
04-16 16:33:37.670: E/CameraHolder(1208):     at com.android.camera.CameraHolder.open(CameraHolder.java:131)
04-16 16:33:37.670: E/CameraHolder(1208):     at com.android.camera.Util.openCamera(Util.java:321)
04-16 16:33:37.670: E/CameraHolder(1208):     at com.android.camera.Camera$4.run(Camera.java:1251)
04-16 16:33:38.231: I/ActivityManager(226): Displayed com.android.camera/.Camera: +1s121ms
04-16 16:33:39.081: I/ActivityManager(226): Start proc com.kth.PuddingCamera:service for broadcast com.kth.PuddingCamera/com.kth.kpns.receiver.KPNSStateReceiver: pid=1272 uid=10033 gids={1006, 3003, 1015}
First off, I would like to thank all who is involved in bringing CM9 to us.
I had issues with the sd saying that it was damaged. I resolved it by trying my wife's sd card (she has an HTC One V running ICS). It read fine on my Elite, so I put my sd in her phone and erased the card. Viola! It read in mine.
One thing I have noticed is that GPS apps don't seem to work..... Tried Waze, which I really like, and one called Scout.... Both load then shut down, anybody else seen this happen?
Thanks again for all the hard work.
So I found an experienced Cyanogenmod developer that can help with the camera and he said he's willing to help.. His name is G60madman and he needs to know if there is a Kernel Source and a Github he can take a look at. So can I have the links to those PM'd to me?
Ok that's it, too many awesome things happening. I'm tired of feeling powerless, if y'all don't see me much in the next week or so it's cause I'm going to try and scrounge up some cash for a laptop. Craigslist had then for under 300 all the time
