Root [ROM][4.0.4][BETA] CM9 for Virgin Mobile and Sprint 10/3/2013
Ok that's it, too many awesome things happening. I'm tired of feeling powerless, if y'all don't see me much in the next week or so it's cause I'm going to try and scrounge up some cash for a laptop. Craigslist had then for under 300 all the time
I've seen decent ones for like $80 on craigslist. Core 2 duo, windows 8, SSD.
Updated Op with new build. You don't need to wipe data if you are already on CM9 but you need to reflash Gapps.
Hey Idk if you saw my post...
I got someone whose experienced with building CM that can help with the camera. I need links go the Github and Kernel Source.
It's working for me. Try again
I saw your post. I can't upload it right now but I'll do it later. Thanks for getting a experienced dev to help.
Alright cool. He's waiting for me to PM him links. :] He built CM10.1 Angry Bean for the Evo V and everything works for that except the 3D portion of the camera but that was just because HTC never released the 3D source so I think he should be able to help out quite a bit.
If anyone wants to deal with crappy download speeds I could always upload it to Send space from my phone and then post the link :)
Is the governor defaulting to performance? I think that might be bad for the processor especially with these high overclock speeds.
Being a total noob. I cant use the "GetLogs"..But I'm having issues with my apps being "Denied" root access & superuser keeps stopping,....I also keep getting error flashes that mt process is stopping, any suggestions & thanks in advanced
I should've mentioned that I flashed the "Updated" version & reflashed the gapps!!...Thx.
So I found an experienced Cyanogenmod developer that can help with the camera and he said he's willing to help.. His name is G60madman and he needs to know if there is a Kernel Source and a Github he can take a look at. So can I have the links to those PM'd to me?
G60s the man! The guy behind getting the camera going on the Triumph. Woohoo..
Any luck on the sd card issue in the new build?
Ken, without a PC it could be tricky. Backup your sd, then repartition it. The elite takes away the partition table and formats the basic drive..
I think Clockwork allows you to repartition, but it probably adds a swap and sd-ext. I don't know if you can just have 1 fat32 partition.
