Root [ROM][4.0.4][BETA] CM9 for Virgin Mobile and Sprint 10/3/2013
What about goo.im for hosting? Or a torrent? I usually have utorrent running I will try and start a torrent tonight.
Been getting an sms every hour for the last 3 hours from unknown sender since i flashed this rom just before noon. It shows up as a bunch of gibberish on the notification bar, and FCs messaging if I try to open it from within messaging. Anyone else experiencing this?
I am getting messages from an unknown sender as well but don't get FCs. Think it might be from cmas.
Yes actually. I only got it once though.
Sprint User:
When ever my screen goes dark and I immediately press my power button to wake it back up, I get a forced reboot.
I'll upload it to Sendspace as a mirror. I'll edit this post with the link :]
Wait a minute.... How is anyone having trouble downloading from Dev-Host? You're talking about Media fire. Did he just add new links? Don't think I need to link it to Sendspace. Dev-Host is the best
Yeah I've gotten at least 3 of those funky texts since this morning. Just got one 10 minutes ago. Anyone try this fix yet?
I don't know if anyone else has had this issue, but I'm unable to create new directories on either the internal SD partition or the External SD. I'm using total commander and I've not tried any other file manager yet.
Also Phenom, I have a request. Would it be too much to ask to include a very simple basic function file browser in the base Rom? It just seems more convenient for quick installs of apps after flashing Roms repetitively, instead of having to continually go to the play store right away.
I am able to create folders in both SD cards . I'm using root browser lite. I will include a file browser in the next release.
Try app2zip you can use it to create a flashable zip with apps you commonly reinstall after a fresh install. I used to do a bunch of apps but now I just do titanium backup and the pro key.
I'm getting that gallery force close also when trying to edit. But I will say this. Even with the few issues this is by far my favorite and current Rom for the Elite.
