Yeah, I have noticed that too. Some 4x4 fit, but others report that they are larger, like 5x5.
Pretty sure its a rom setting as I didn't have this problem with my Triumph under CM9 (before it died).
Anyone else find that their widgets are too big? For instance instead of 4x1 for Tweetcaster it is trying to do 5x1 which is too wide for the screen?
Fancy widgets 4x2
If it helps any, I've only noticed that in the native trebuchet launcher.
There is a way to adjust the grid size with the stock cm9 launcher
Just go in to Settings>Launcher>Homescreen>Grid Size
phenomx4,
I haven't been around in a while, I've too busy with work. I just wanted to say great job getting CM9 going!
Have you been working on the Camera and NFC? Which source are you building with, Code Aurora? Do you have a github or other public site hosting the build files?
Keep up the good work.
phenomx4,
It was this way in the stock ROMs too, the _externalSD was just a short cut. You could still get to the uSD through /mnt/External SD is separate mounted drive rather than folder in internal sd. Really like it. Thanks so much for your great work.
? i installed the twisted rom then added the 4 13 kernel ran awesome and my camera worked fine then i installed the newer kernel to the same rom and the camera could not connect i dont know much about all this so my ? is why would my camera work with the 4 13 on my 2.3.7 but not the newer kernel they both were designed for the cm9 update right
even when i flashed the newer kernel on top of the gingerbread rom i was able to run my benchmark at 1.8 and let it run 6 hours no problems or reboots just no camera
