chris1975bour
i guess my ?was why would both cm9 kernels run fine on gingerbread but the camera only runs on the 4 13 sorry bout the noobe stuff just trying to learn ..and thanks for your help
Just a curious question...
Are kernels specific to software version(OS version) ? Is it advantageous to have a kernel version upgrade if coming from one OS version to a new one?
Interesting...
So, you flashed a stock based gingerbread 2.3.7 ROM, then flashed an older kernel from the CM9 build and the camera worked (gingerbread and a slightly older CM9 kernel together). You then flashed a more recent kernel from the most recent CM9 build and then everything but the camera worked. Is this correct? If so, based on what giantpune and I learned building CM7, my best guess is that this mostly worked because our device and version of gingerbread was cobbled together using source, hardware and configs found in more recent android versions. We both came to the conclusion that this device is a mess from a developer's perspective.
Edit: Nevermind, see phenomx4's answer.
I'm still wrapping my head around some of this, but wouldn't that give credit to the idea of backporting the gb camera drivers to get it working on cm9?
Its been done from eclair to froyo to Gb...so its just a matter of drivers and libs imo.
Cause I'm thinking if the 413 kernel has drivers that work with gb libs. Would the gb libs + 413 kernel be used some how on ics?
I'm already using gb libs for cm9. It loads then crashes the camera.
So would maybe the post above yours show that the OE has the new driver then and everything needs to be implemented?
I think I mentioned it a while back. They just did this with the Motorola Triumph. I think they used some of the GB drivers with a modified CameraHal. They documented a lot of their patches in the github source. I think it maybe worth looking at. I assume its more on an api patch level rather than a low level hardware level.
Camera forceclosing was what we got on the Triumph before christmas on CM9. They've now got both back and front facing cameras working.
I am already doing this and it's really close. It loads all the way but before it can show preview it crashes the camera app.
Are you putting the libs in system/lib/hw? Seems I read that was a key difference versus gb. I'm sure you are just putting it out there.
It gets built and then put there.
So once the camera is fixed would this officially be called beta?
Or would it be beta when NFC is also fixed?
I second that emotion, It is way better than any alpha I've ever seen....I am a ready tester as well seeing how I'm a "serial flasher" & all...lolThis dev is hard on himself when naming his builds lol, alpha builds usually boot and maybe sensors and the launcher work. Honestly its been beta quality for the last couple releases. Once the camera is fixed its an RC imo. Phenom has done a great job and its a good clean build. :thumbup:
