starkraving
Android Expert
@Phenom
Still playing with the service.jar and hard coded the
Forgot to enable them since I had to start over on the kernel about 4 times because some mishaps with the kernel. Since I'm going to update the ROMs again tomorrow I'll enable them.
Latest Build (9-17-13): https://shared.com/ergzxyue1e
hey does anyone know how to install this? im new please? i really want cm9 on my elite
With the 09.17 build, I started getting the odd text messages from an unknown sender. Anyone else experiencing this? Thanks!
This rom is running really well for me. Love the status bar options!
Darkone: What is noop?
Thanks @phenomx4, nice improvements and seems more stable. Been running it from late yesterday and all day today. Also tried doing the data restore from the August CM9 backup to this build, thanks to the @Artine post " [GUIDE] to Retaining Data After Flashing a New ROM ", saved much time of having to reinstall and having to sign into each app again. One feature that seems to be missing, unless I'm the one totally missing it, is the navigation app from the VM stock ROM. Although the GPS receiver seems to turn on and all, no nav app and can't seem to find a decent replacement from the play store...any recomendations?
@Phenom
working on a patched version of Google Wallet for AOSP roms just getting compiling errors atm. Think I have it sorted.
New to the forum but I've been running this rom for a little while, a few things that I've noticed are: video player isn't able to play mp4 (this might be an android problem not rom), camera error "can't connect to the camera" if you go from a "camera using app" ex. take picture in instagram/snapchat then switch over to normal camera, and lastly instagram closes when trying to upload video, and will not recognize pre recorded videos for upload either
Other than that awesome rom, turned my oe into a monster
If you flash black ice 2.2 over this u will loose the new options that Phenom made
2 small things i've noticed is flash will not stay on during video recording and if you use snapchat video recording it will usually crash or just take a picture instead. this could be similar to the skype issue but I just wanted to place that up as well. Otherwise great work you're doing
Is there a way to increase scroll speed and resolution? Words are so small it's hard to read.
How long into recording does the flash stay on and yeah it may be related to the Skype issue. Looking into it.
