Mines at 15762
He used Quadrant. If you have like 15000 you must have used Antutu. Two completely different scoring systems.
Mines at 15762
Check ur notification toggles, make sure screen timeout and stay awake aren't on, also make sure a lock screen is selected in options
Switch to cwm, can u give me the specific error eg: status 6, status 7 and I will look into it
I had this same problem with CWM, any ideas? I tried clearing the cache because that worked once before, but it didn't this time. Now I contently get stuck at boot. I still have access to CWM and the moonshine zip is on my SD card. Any way of just getting by phone to work, ROM doesn't matter would be greatly appreciated,
Just a question but y does no one make backups??
Are the ppl with issues getting status 7 set_perm some changes failed??
The rom is great. Whenever I send a text, I get a little warning that says, "Insert a SIM to send SMS". The messages still gets sent, but the message shouldn't be there. Maybe I missed this information somewhere, but how do I turn that off? Thanks!
I think the problem is I tried clearing my cache and now it is stuck. I tried restore and it comes up with an error at when it gets to cache.
Do an advance restore of system and data only.
I think I found a glitch?
While using the Google Now Launcher.apk from the first post, the apps that are installed on my SD card disappear from the homescreen when the phone is rebooted. Can anybody else duplicate this problem? Is there a fix?
-Thanks
Edit: There doesn't seem to be a problem with Trebuchet, the default launcher.
Glad u like itthe sim message is from hangouts itself and not removable, all is fine it just shows a toast
I'm gonna recommend EvolveSMS. Maybe not stock enough or whatever, but it does have preset APN's that allow you to set it to Virgin Mobile. 100% flawless texting and MMS without the sim message.
Just a personal preference and letting people know it exists.
Will you move the clock back to the right side, or make that an option?
Just for u
Thanks, but i still need to get my phone working, are you willing to help? PM me if you are. I would greatly appreciate it.
