roadkill42
Android Expert
I'm running the dedoxed from deleted hang outs I dont get the toast I dont use hang outs any ways
if u didn't update hangouts u wouldn't as only new version causes toast, and Chris ur correct I didn't change anything as far as apn/network is concernedI'm running the dedoxed from deleted hang outs I dont get the toast I dont use hang outs any ways
not sure about miracast but I'm pretty sure chromecast will workDoes this phone support miracast? Probably not just asking.
try a reflash and next time don't say plz help, just explain the exact problem, what ROM ur using and how u flashed etc... the more info the better, also a logcat would helpwhen i reboot my wifi does not work plz help thx
I almost forgot happy belated fathers day to all the dads on here![]()
I just checked and I too am experiencing this, will look into itjust installed 2.8, having minor issue with settings crashing when going to settings->device->apps. it doesnt always crash but most of the time it does. might reflash later if no one else has the problem.
this is cause by zte code trying to cast to abslistview which controls the list view animation, will be looking more at this when I get timeI am experiencing the same issue every time I go into settings / apps . Crashes on me every time . Doesn't crash with the rom stock but soon as you use play store this happens . I also noticed that soon as the phone reboots after a flash on setup play store crashes and hangouts . another thing that happened to me is that the settings reverts to a single tab when it's supposed to be a 3 tab settings system/device/network . The culprit could be play store . Went back on 2.7 and problems are gone . Much appreciated though and thanks again .
I really appreciate your effort . I am not in a hurry at all . 2.7 has been probably the best ROM I have tried on any phone and it's working perfectly for me . Take care of yours first . I am actually going thru a legal issue that I wouldn't wish on anyone so I know that life comes first and then other things come later . My problem will be solved soon . I'm sure most people will be satisfied with 2.7 and if they are not , it's because of selfishness and a lack of sensitivity . You have gone leaps and bounds to make strangers happy and that to me is priceless . Thanks again .
its in my devhost, only issue with 2.8 is accessing manage appsCan someone send link for 2.7? I erased by accident
I have yet to experience any time issues?? if u can give me more details as to when it happens or if it completely random, only when alarm is set, etc...another 2.8 issue.
this morning i had the alarm on the phone wake me as usual, only to find out the clock was running 7 minutes late. i saw earlier comments about the clock being off prior to 2.8 release, was this problem introduced in 2.7? i had no clock issue with 2.6, i skipped 2.7.
