Just got a sprint awe update notification. Can't install it because I am using twrp. Anyone else get one? I am using 2.8. Can't replicate it again as the update menu in settings is disabled.
It was about a 29 MB update so I doubt it was a prl update. If it pops up again I will take a screen shot. Also tried to see where it downloaded to but I am not sure where it would of put it.
My battery seems to be draining quicker than stock ROM. Is that normal? I've deleted widgets and hibernated apps since but not much difference
I have yet to recieve this?? U said a sprint update?? The update menu in settings works??Just got a sprint awe update notification. Can't install it because I am using twrp. Anyone else get one? I am using 2.8. Can't replicate it again as the update menu in settings is disabled.
Did u get ur phone at walmart?? Reason i ask is it has a walmart boot anim lol, where do live??
It just adds walmart support it looks like only patches files, weird thing is i havent got prompt yeti know i saw that. custom virgin mobile boot animation? I got it at target on black friday. I don't know what any of the other changes are though. I am going to go back to stock and flash it. Probably still won't see what has changed though. Oh I live in Long Beach, CA.
flash to stock then bk to awe inspired wont do anything needs to b integratedIt just adds walmart support it looks like only patches files, weird thing is i havent got prompt yetflash to stock then bk to awe inspired wont do anything needs to b integrated
No i already looked at update, just seems odd no one else has received it, our phone already has sprint, boost, virgin mobile, and now it looks like straight talk support with this update as far as i can tell, we will c what comes in the next few days as ota updates are usually not all at onceWould a logcat from stock with the update help any to see what has changed? I only see the boot animation file mention walmart. Why it shows up as a sprint update and b06 i am not sure either.
screenshot
U have helpedDang and i thought i was giving back to you great devs before someone else. I guess i got to find another way to contribute as you guys have made my awe awesome!
it will need to b integrated into the rom, which means i have alot of this work to do lol could u flash back to stock from guide in my sig, take all updates, then upload a system dump for me
U have helpedit will need to b integrated into the rom, which means i have alot of this work to do lol could u flash back to stock from guide in my sig, take all updates, then upload a system dump for me
Sure. Just guess i have to adb the stock recovery as it fails in cwm and twrp. Though i think i will try the updated script by DPackMan first. When you say all updates do you mean apps from the playstore as well? Because then the dump would have my google account info. Unless it saves the updates to system then i can still wipe data right?
use this zip, flash with any custom recovery [u will loose all data and b back to stock recovery]!!! then boot up take all updates then "adb pull system update/system" zip it and post
