Root [ROM][ACS] GB UNleashed 2point3 [GBU-3/20/11] " KING STYLE "
damn you frenchy!!! Your just feeding my addiction. they give you a brand new evo and you just go nuts:D i'm gonna have to add this to the ever growing list of roms to flash. damn me and my flashoholicism:mad:
I'm just trying to give you fa's your fix, and get my own while I'm at it lol :D!
well while im currently using sense i think im gonna have to switch over and check this out cause it looks bad***
oh yes you did im sorry i forgot to answer. its been working great. the real test will be at work when its sitting in my locker with poor reception again. didnt realize having the mobile network off would save so much battery. also didnt know you could still receive sms and calls.
Glad it's working out for you. Let me know how your battery holds up after you pull it out of the locker :D.
Well...here's my reason to try something new :p. And I was loving miui but kings roms are slick
Sweet! Also, for some reason, when I connect my phone to my pc, windows tries to find a driver for the phone. Why does that happen? I'm still able to use the phone as a drive but the pop up will get annoying.
Mine does that too....I don't pay it any mind though.
2 major issues soon far. Titanium says it is restoring apps but they are not there. Also...check your about phone battery level vs displayed battery icon. My icon isn't changing :(
Have wiped and really installed 3 times and can't get my backups to install...or the battery to show correctly. Major bummer because this rom is flying
The battery is most likely set up in 10% increments so it may only change when it drops another 5....but the inability to restore with titanium is odd...that has never. Happened before
I was having the same issues with Titanium so I went to Evervolv and my back ups came back.
I know a lot of you would appreciate this :p.
Working:
4G!!
Rear Camera 8MP!
Front Camera
Camcorder
MMS
Wifi
Sound
GPS (Works best with wifi ON does not need to be connected to a network though. also might have to open maps then turn on gps. once its located you your good to go)
Everything else except the list below
Not Working:
HDMI
If you would like to try it out, here you go:
[ROM][ACS] GB UNleashed 2point3 [GBU-3/20/11] " KING STYLE " - xda-developers
Smaller than CM7... any reason why?
Oh good, i was about to flash this...guess ill wait till tonight for the new build, i have to have my titanium working...
