I am on 1.90 radios. I can't post a public link to r1...gapps is included and they have copyrights on it ....but I do have it
The set up bug is caused by 2 set up apk included. I thought he fixed that in r2
you definitely do.. try flashing the format all twice...then each of the format options in ra twice...
it's an issue I have seen more than once
Nevermind, I did some reaserch and found it's a Evo issue that should end up with me in a new Evo from the factory. :\I've been running this for about a week and it is AWESOME!!!! THANKS!
Only one issue: my phone all of a sudden started rebooting itself, going to the "HTC EVO" screen, shutting off, then back to the white "HTC EVO" screen again, over and over.
I can get it to the fastboot screen, but as soon as I try to go to recovery (or just turn it on or reboot), it goes back into the "HTC EVO" screen and off loop. I hope my phone isn't' dead.
Please help. Any ideas to save mah fone??!! :'(
I will be back on Kings', though, cuz it rocks!
Thanks Mr. Ed...you are like the Evo Guru...you help develop it?!sorry I never noticed your original post...can you get into bootloader?
I have run into issues like this where loading into bootloader and flashing a stock ruu and then basically starting from scratch
I don't use market hotspot at all now. Just built in and yes..
.. it works on 3g and 4g
Frenchy try wiping cache and see if that fixed it
Try clearing dalvik and cache andbthen gapps again
And no.....I didn't help develop the evo lol. I was waiting 5 years for a phone like this tho. And I spend entirely way too much time with my phone
