is there an SBC version of this kernel?
How did you get it working? That error is getting annoying.
I am new here so go easy if this is a dumb question. I have been flashing like crazy over the last 3 days and I have pretty much tried all the roms out right now haha. Anyway I am trying out Kings 2.3 and am wondering if there is anyway to make more than just the 3 home screens? Can you only have more in sense? Thanks
P.S. Where is the market? I have no app for it?
You need to download the gapps zip and flash that to get the market.
If you press the menu button on the home screen then tap preferences the top choice is the number of home screens you have. you can change it there.
I noticed today that under the about phone information screen in the settings, the mod is listed as being version R1, when I'm sure I flashed R2, can anyone else confirm this, is it just a typo?
Is there a way to get rid of the task killer that was pre installed?
It doesn't show up in titanium or something?
Its a typo
Odd, mine says R2
That's relieving. I was about to reflash to make sure I had R2. I wonder why other peoples say R2 though.I asked the Dev in his XDA thread and he said he forgot to update the name from R1 to R2, and barely updated it to say the correct build. So yes, it's a typo.
Ahh I see, but there's no difference between the version I have and the version thats correctly labeled, correct?They more than likely flashed the ROM after he made the correction.
Correct.Ahh I see, but there's no difference between the version I have and the version thats correctly labeled, correct?
never once have I had this happen. I would be willing to bet there is something else at play here..or that it is on nightly betas
I have also hit the repeated boot loop "brick" that I keep reading about (on different roms) and recovered from it
Honestly there is so much room for human error.
I have only been able to come up with one truly bricked scenario ... running mix mash of radio pri hboot versions and needing to do an ruu...basically no revovery no bootloader access... once "could" be bricked at that point.
In my case...as long as I have been able to get into bootloader...I have been able to recover.
It seems like this new bootloop issue wont even let you into recovery. But it sounds like some kind of hardware failure to me because while CM7 users have experienced it, so have some Sense users. Its apparently very nasty though and there us no known fix for it yet that cures the problem 100% of the time. The thread is over on xda in the q&a section.
