Root [ROM][ACS] Kings SENSE TWO POINT THREE
They shouldnt have gone anywhere. Tib back ups are on your sd card. Just try installing Tib's busybox by clicking problems an get busy box first...
still no dice. busy box running already running... I went ahead and tried to get a new one but its the same version.. and still no apps.. going back to nandroid to investigate
Oh I'll pull the damn wallpaper once i flash it lol ima try misfits first though i think.
LoL dont get testy matt LoL jk thanks man! 'preciate it. Id do it, but i figured sine yall are trying it out today, and im planning on waiting a bit....
Hey I just flashed this rom and I tried to reboot into recovery but I can't start the phone in recover for some reason. I held down the power + volume down button and it just started up the phone like normal, no recovery mode. Anyone know how to get to recovery with this rom???
LOL its always the same...hold vol down + then hold power down till it comes one. Or use quickboot app in market...or you lost recovery...but it should have gone to hboot so...disable the fastboot option in the rom heard that was causing an issue getting to recovery
It's a leaked version of Android 2.3 w/ Sense. All the other Sense based Roms you've seen have been based on Android 2.2.
It is a little confusing because the build of Sense you've seen on all Roms has been sense 1.0. Some of the Z ported Roms run Sense 2.0. This appears to be Sense 1.0 with some 2.0 enhancements included.
So this Rom is Android 2.3 w/ Sense 1.0 + a sprinkling of Sense 2.0. Clear as mud?
i thought my head was about to explode but actually you did a pretty good job explaining it :D
Yeah, ive had that happen to me a couple-a times... well, before i got the quickboot app :)
Ya there is a u tube explains that if fast boot is selected when u power down it just sleeps ... So u have to unchecked it to get in recovery
Ok, running this. It is fast for sense. So far stacks up to aosp. Pulled the wallpaper for you doofus have to post it later gotta go bed sheet shopping :(
Yeah, that's one of the few things from the new Sense that actually made it into this build. Unless you disable that, you're not actually turning the phone off. You have to start from a completely shutdown state to get to hboot.
:confused::confused: Not worth flashing? I believe whomever is King's fan should flash this;)
I am a kings fan been running him solid.. but it just does not do any thing for me the scroll still jitters and apps still take a moment to late to come up.. his r3 build was perfect though...........I dont know I am new to all this but the GB 2.3 he put out is awesome and they dont compare.... I only gave this rom about 5 hr before I switched back
Going to try and catch up with evo stuff today
My experience with this rom
No camera...white screen
no apps to SD ....get the can't mount SD error
Got 1 reboot during a call
Will read through all the posts today and tomorrow but I am swamped :(
Hmm mine is running fine. Flashed netarchy 4.3.4 almost immediately to fix screen brightness, couple of fc I fixed with a tib data wipe but other than that....
