In version 0.6.15.1, I have been experiencing some random reboots due to turning Wi-Fi on. Is this a known issue?
Upgraded yesterday from 6.14 to 6.15. Battery wasnt great on 6.14 but I am getting 3.5 hours of battery life from fully charged batteries now. I have two and have gone thru both since 8:00 am (3:30 now EST). No calls and Wifi and BT are off. I killed all unneccessary programs. Was hoping to get most of the way thru the day on a battery.
Anyone else having a similar issue and a clue what is causing it?
I have not seen that happen on my phone yet.
I'm having an issue with Google Play Store. I tried to download a couple free themes, and when I hit the install button I got "Error processing purchase DF-BPA-09" I've already cleared data, force stopped, and re-flashed gapps and still having this issue. Any ideas?
Did you clear data for "Google Services Framework"? Because that's the one you have to clear in order to get it working again.
ive seen a few posts about google errors and some seem to be on googles end, but just to be sure, did u flash the correct ICS gapps and not the gingerbread one?
I'm just an average user, can't thank you enough for the hard work done on this mod!!! I absolutely <3 it.![]()
Im having a issue with my bluetooth headset. When Im listening to Tune In Radio, it will say disconnected, then connected again numerous times. I did what mantera said and unpaired and paired again, again the same thing is happening. Also, it cuts in and out, repeatly. Thinking that this might have been a possible streaming issue, I tried with my mp3s that are on my phone, again cuts in and out repeatly. Again, trying to eliminate possible causes, I used the same bluetooth with my tablet (streaming from tune in radio and listening to my mp3s). The bluetooth worked flawlessly in both instances. This leaves me to believe that theres a issue in the CM9 rom. Has anyone else had these problems with their bluetooth on CM9??
What's less than three?![]()
I have tried changing governor settings and to no avail, it makes it worse. This is getting very frustrating. Does anyone have any suggestions?? I will put my phone in the leather case and have it less than a foot from my bt and it seems to get worse, cutting in and out, Ill take it out of the case and it will play fine for a few minutes, then all of a sudden it cuts in and out. It also keeps disconnecting, sometimes when the bt is just several feet from the phone. Im about ready to throw this thing, its making me really upset. Does anyone else have these issues and can shed some light on this subject?? It cant be the bt because it works flawlessly on my tablet. Could it be the rom?? I had these problems on CM9 .14.0, tonight I updated to .15.1 and still Im getting the same problems. PLEASE HELP!!!!
Ive been having this problem almost a month now. Just within this month, I have used my bt heavily everyday. Currently, I switch frequently between CM9 and CM7 and I have the same problems with CM7 (whyzors build). About 6 months ago, I would use a radio app (tune in radio) at work, and I dont remember which rom I was on back then (I think maybe stock), but very rarely would it cut in and out. Now when I use tune in radio, it cuts in and out, just like when Im on the phone. Last night, I did a factory reset and installed CM9 (.15.1) without most of my apps (thinking maybe a app might be causing this problem) and its already cut out a couple different times but not as bad, although I have only been using this for about a half hour.
Does anyone know where I can get the stock rom and market file so I can try changing to stock and see if it still happens. Meanwhile, I will keep using my phone today with bt to see how much it cuts in and out. Hopefully we your guys help, we can narrow this down to whats causing this. Thanks for the feedback.
I've seen Chrome Beta crash a whole lot more often than usual since the 0.6.15.0 update. Scrolling sometimes turns into some weird glitchy-like mess, and eventually it crashes. I haven't tested other live wallpapers, but my live wallpaper will disappear and the background will be black after Chrome crashes.
I honestly don't know if this is something to do with some recent Chrome Beta updates or if it's really from the update to 0.6.15.0.
Mantera, I was wondering if the new Linaro build optimizations that were recently added to CM9 would be possible to be ported over to this ROM.
