minikirchner
This is a update. I have used the bluetooth on CM9 today. I have tried changing the governor, I tried 3 different governors and then used my bt, it cut in out alot more than with the interactive governor (default setting). I drive quite a bit and need to use my bt daily. I put the governor back to interactive and I got the same issues, saying disconnected/connected reapeatly, then it will disconnect and not connect again. I will manually get into settings and turn the bluetooth off, then on again. It freezes saying turning bt on, it was like like that for about 20 minutes. I will then reboot and when thats done, the bt connects fine, then about 5 minutes later, it starts disconnecting/connecting again, having the same issues, I turn bt off then on, it again freezes, I have to reboot again, tried this 3times and the same thing happens. Please help, anyone?? Does anyone think updating to the .14.1 will changing anything with the issues Im having?
Changing the governor just fixes the skipping from audio that you had mentioned. It won't fix the Bluetooth issues. Maybe you have a defective phone?
