Kinda, I just downloaded the xperia play ics beta source from here. Haven't had a chance to look at it yet though.Hey so I was thinking just now...are there any phones similar to the triumph on ICS? If so...maybe we can rip their drivers? If that makes sense?
For some reason, Wifi never works for me on this ROM. Yes, I know that it's alpha, but I'm just saying... Anyhow, one thing I believe that mantera should tweak on this ROM is power management as this ROM really seems to run hot.
Thanks, but Wifi doesn't seem to work for me on ANY ICS rom. I have no clue why. It just freezes up at "Scanning" and never gets past that. Considering that in my house I get very low 3G speeds (most of the time at 1x), for now ICS is unbearable until someone gets to the bottom of this. I expect these problems since we're in alpha, but how come Wifi is listed as working and nobody else has Wifi issues but me? I did a full factory reset after making a Nandroid backup... Then I installed the flashable zip. Is it just me or is anybody else having Wifi problems on ICS?i nvr had an issue wif wifi n power management on this. if u do need those u should try liquidsmooth by austrie or aokp by gannon. those r the same but has more features. wifi n power management on those r excellent. no offense to mantera as he was the first to bring ics i believe to the triumph. i thank him for that n for all he did to make a crappy phone really worth it![]()
Thanks, but Wifi doesn't seem to work for me on ANY ICS rom. I have no clue why. It just freezes up at "Scanning" and never gets past that. Considering that in my house I get very low 3G speeds (most of the time at 1x), for now ICS is unbearable until someone gets to the bottom of this. I expect these problems since we're in alpha, but how come Wifi is listed as working and nobody else has Wifi issues but me? I did a full factory reset after making a Nandroid backup... Then I installed the flashable zip. Is it just me or is anybody else having Wifi problems on ICS?![]()
Thanks everyone. A reboot fixed it. Didn't expect the solution to be so simple.
LOL I cannot believe myself. I can understand complex technical concepts but often forget that the simplest thing is to reboot!I've worked in tech support, and can confirm that it's not at all uncommon for rebooting to solve the problem.![]()
Who is working on this rom...Been to long and still no update.....proximity sensor sucks, still dont turn on when phone is away from face
Im having a issue with my bluetooth headset. When Im listening to Tune In Radio, it will say disconnected, then connected again numerous times. I did what mantera said and unpaired and paired again, again the same thing is happening. Also, it cuts in and out, repeatly. Thinking that this might have been a possible streaming issue, I tried with my mp3s that are on my phone, again cuts in and out repeatly. Again, trying to eliminate possible causes, I used the same bluetooth with my tablet (streaming from tune in radio and listening to my mp3s). The bluetooth worked flawlessly in both instances. This leaves me to believe that theres a issue in the CM9 rom. Has anyone else had these problems with their bluetooth on CM9??
how do I change these settings? Ive never messed with the governor setting before and changing these settings, will it affect anything else on my phone?? Thanks for your feedback..
