flash works for me and im now getting through a whole day on one battery again. woot page 23![]()
Quick question here: I have the original GAPPS that was posted here still on my SD card. Can I use that with 0.6.7 or do I need the new GAPPS?
I don't want to sound like a terd, but you could always try it and report what happens.
I think it would ask to update the individual apps like after the second boot or so.
And you could go to the market and check in the MyApps section to see if you have any updates.
Thank youi am using the original GAPPS posted here since .5.0 works fine for me on 0.6.7![]()
What does a "terd" sound like?
Wifi won't turn on. Is this a known issue?
wifi should turn on. You have to reboot for it to be able to if you haven't already.
my wifi has been broken for about a week now...ive tried EVERYTHING and it wont connect to any router at all...i flashed to CM9 6.3 and my wifi hasn't worked since...i even went back to CM7 to no avail...please help
Have you tried 0.6.7 yet mine works like a charm make sure you reboot n manually connect.
Hmm, it would have to be a user error.
I can't imagine the software would work for some and not others. Just doesn't make sense.
It sux everything else works fine...ive followed protocol, as always but i dont wanna buy a new phone if this can be fixed
Yah, also, I've never been able to get my mms working on anything other than stock rom.
On ICS, how do I enable applications from "unknown sources?"
