idk, but standard youtube videos have always been working for me....![]()
Standard has never worked for me as long as I've used this from. Tempted to do a fresh install.
It seems that wireless tethering does not work. I tried connecting it to my tablet & laptop with no success either times.
so i have noticed since 6.8.9 my phone overheats and runns out of battery like really fast is this update no longer letting my phone go into deep sleep or do i need to do a fac reset![]()
Great work on this ROM guys! I've been updating regularly every since it came out. I noticed several subversions back that MMS was listed as functional. Every time I flash, I do a complete factory wipe, wipe the cache, install the ROM, then the gapps. Yet, I've not had any luck in getting MMS to work. The message hangs for hours, saying "SENDING". Then it returns a failed send error. Thinking it might be due to the size of the images, I tried loading a small jpeg onto my SD card, and sending it in the MMS, and it still fails. Has anyone else experienced this, or do I have to change any settings to get it functional?
I finally got around to loading up the 0.6.8.9 update and my Bluetooth headset works fine. I downloaded the keynrtracker.apk (not the remapper) to log the keys, but I didn't change anything... These are just stock.
Motorola S9 HD Bluetooth Stereo headset
Play/Pause = 200
Track up = 163
Track back = 165
The phone button brings up the Bluetooth voice dialer so the key wouldn't log in the app, but it works fine.
If anyone needs any further info, I'll do what I can.
Pic of headset, if you're curious...
Can the tun.ko module be compiled (and possibly enabled by default) along with OpenVPN support? This was quite handy in CM7 and I hate having to restore back to CM7 every time I need the VPN.
Also im not having any reboot issues with overclock. Even running at 2Ghz, i have ran my phone for hours and never once had a freeze / crash.
I am soooooo dying to get back on this ROM.....with every ICS update I start scouring through the change log to see if the cam's been enabled, but alas!! Keep up the great work!
Still doesn't seem to work for me. No biggie.Note: Wired Headset media controls MAY work. I tried one last fix. If this doesn't work, then it'll need to go on the back burner for now. Let me know.
