how do i fix my phone now?![]()
If u have a Backup.. u should reboot the phone go into the CWR and u should restore to the backup.
But i am not sure if that will do the trick. Going to have to try that.
Yep Me tooGood thing it was my old phone.
hmm bootloop.. sigh..
That means it needs modification to work on Triumph.
, flash cm9 from mantera first then apply the zip, im going to try this tonight.
!I can't boot into recovery it just goes directly to the first splash screen...and stays there
Take the battery out and put it back in And Hold the Volume UP and Down And then try to turn it on
You guys do know thats not the whole rom, flash cm9 from mantera first then apply the zip, im going to try this tonight.
Cheers!
I have been..constantly since it started looping
) I'm permanently switching to CM9I got it!!!!! Its finally fixed!!!
Yes tell us how come on man lol
lol sorry for the confusion...i meant that i fixed my bootloop, i tried again and it failed.....this fix will not work
sorry again for the confusion
Not sure if the changes in are in the kernel, but if they're not then you can try switching the boot.img's in the roms and flashing it that way. At your own risk of course.
But maybe we could copy those modifications on our kernel if we can find out what all he did
... Maybe we should try and get hold of the person who made the camera work for them.. tell use what modification he did.But maybe we could copy those modifications on our kernel if we can find out what all he did
Ive got all files in place that were in zip and this is what I get when opening camera D/OpenGLRenderer( 430): Flushing caches (mode 1) V/CameraHolder( 2035): open camera 0 E/CameraService( 123): Camera HAL module not loaded E/CameraHolder( 2035): fail to connect Camera E/CameraHolder( 2035): java.lang.RuntimeException: Fail to connect to camera service E/CameraHolder( 2035): at android.hardware.Camera.native_setup(N ative Method) E/CameraHolder( 2035): at android.hardware.Camera.<init> (Camera.java:320) E/CameraHolder( 2035): at android.hardware.Camera.open(Camera.ja va:280) E/CameraHolder( 2035): at com.android.camera.CameraHolder.open(C ameraHolder.java:131) E/CameraHolder( 2035): at com.android.camera.Util.openCamera(Uti l.java:267) E/CameraHolder( 2035): at com.android.camera.Camera$4.run(Camera .java:1098) E/CameraHolder( 2035): at java.lang.Thread.run(Thread.java:856) D/OpenGLRenderer( 430): Flushing is this the same errors we were getting before
hmm okay well i am not all that good @ codeing these type of stuff but idk i think i will try to see where i can get with it.
Heres a full log if needed http://db.tt/2NgPQptp
