rowlers
i didnt wipe i just flashed straight over the top
one thing to note though, you are not using manu 1.4, from what i remember you are using 2.0
make sure the governors for screen off are the same for wake (on demand)
i didnt find 2.0 as stable as 1.4 and more of a battery drain.
if i recall you had wierd reboot issues before this didnt you? and we thought it was the overclock? or am i thinking of someone else...
ive had this flashed since 2:30am this morning. its been on overnight, been hammered in the garage on poweramp and has my set cpu configs the same.
the only thing im not doing is messing with the voltages, mine are stock kernel voltages for manu
I'll certainly give it another go... It is me with random reboots, but nothing like 6 this afternoon.. Maybe 1 a fortnight or so.
Both Governors are the same - on demand
I'll also try it with the 1.4kernel and report back, battery is a it low so It needs a charge before any more fiddling!
cheers rasta
