Jon_LTD
Android Expert
its not
we even tested to see if it got it from the google servers but it doesnt.
heres a test for you. change the time on the phone then set the time to automatic and restart phone.
So why is the option there?
its not
So why is the option there?![]()
AF is just a fastboot command gui, if its stuck pushing it then the program is not working properly
its a good reason we recommend learning fastboot commands manually as if a gui goes wrong when its such an important flash like hboot. its a perm brick
follow the fastboot faq to get fastboot setup correctly then manually flash it
Okay first of all, I'm a dick LOL.
I assume you were being sarcastic in the "which ROM thread" Dan, when you said this ROM sucked. I ONLY just released you're the dev for it LMFAO!!!
So with that in mind, I have 110% confidence in giving it a whirl.
Looking at your downloads, how do I know which is the right hboot to install? The 60, or 65MB one?
Looking forward to trying this baby out.
Andy.
Okay, looking at most of the other posts in here, that mention hboot size, I took the plunge and am currently flashing the 65MB one through Android Flasher.
However, AF seems to be stuck on "Pushing, and Flashing HBOOT".
I remember when I flashed CWM the other day, it worked REALLY quickly.
Here's the sequence of actions I took.
1. Booted in Recovery.
2. Wiped Davlik Cache then User, System Data.
3. Rebooted to Fastboot.
4. Flashed the 65MB HBOOT
Now its been stuck on Pushing, and Flashing for ages. I dont want to turn my phone off incase it buggers it up.
Any suggestions guys?
Andy
The exact same thing happened to me once. Then, I realised I was using my brother's laptop which did not have HTC drivers installed. So just make sure you have both HTC and hboot drivers properly installed, boot into hboot, cycle to fastboot and flash, it should work.
