nicka3200
Android Expert
no need to wipe for a kernel as far as I know. I never have![]()
OK thanks. Just flashed the kernel. I'll see how the GPS works tomorrow.
#!/system/bin/sh
sleep 30
echo 19200 875 950 > /sys/devices/system/cpu/cpu0/cpufreq/vdd_levels_havs
echo 128000 875 950 > /sys/devices/system/cpu/cpu0/cpufreq/vdd_levels_havs
echo 245000 875 975 > /sys/devices/system/cpu/cpu0/cpufreq/vdd_levels_havs
echo 384000 900 1000 > /sys/devices/system/cpu/cpu0/cpufreq/vdd_levels_havs
echo 422400 925 1025 > /sys/devices/system/cpu/cpu0/cpufreq/vdd_levels_havs
echo 499200 950 1050 > /sys/devices/system/cpu/cpu0/cpufreq/vdd_levels_havs
echo 614400 1000 1150 > /sys/devices/system/cpu/cpu0/cpufreq/vdd_levels_havs
echo 729600 1050 1175 > /sys/devices/system/cpu/cpu0/cpufreq/vdd_levels_havs
echo 844800 1125 1225 > /sys/devices/system/cpu/cpu0/cpufreq/vdd_levels_havs
echo 921600 1150 1275 > /sys/devices/system/cpu/cpu0/cpufreq/vdd_levels_havs
echo 998400 1150 1275 > /sys/devices/system/cpu/cpu0/cpufreq/vdd_levels_havs
echo 1036800 1175 1275 > /sys/devices/system/cpu/cpu0/cpufreq/vdd_levels_havs
echo 1075200 1200 1300 > /sys/devices/system/cpu/cpu0/cpufreq/vdd_levels_havs
echo 1113600 1225 1300 > /sys/devices/system/cpu/cpu0/cpufreq/vdd_levels_havs
echo 1152000 1250 1300 > /sys/devices/system/cpu/cpu0/cpufreq/vdd_levels_havs
echo 1 > /sys/module/bcm4329/parameters/wlLowPower
)Hi
I have been using this ROM for a couple of weeks now and loving it. However I have one little issue.
I'm trying to play a AAC stream through an app (XiiaLive Lite) and it appears to recognise the stream (32kbps AAC+ 44.1kHz 2ch) and buffers then gives an error - "android media failure 1|unknown".
The stream I am using is [FONT=&quot]'[/FONT]player.arn.com.au / alternate / 973fm.pls' (Please reassemble - I can't put a link in my first post)
I just tried what appears to be the same stream (just shows 32kbps AAC) using the Tunein Radio app and it plays ok. Using a different app isn't really an option though as I am using Tasker to start and stop the streams through XiaaLive.
An issue that isn't really affecting me but may be related is that the stock music app force closes whenever I try to open it.
Hoping someone has some ideas on what the problem could be...
Well it's bad news for me with this kernel, i have 2 camera apps and both fc on me, i tried restoring my nandroid I made prior to flashing this kernel but the problem is still there, ive reflashed the rom and still no good, gonna have to wipe and start all over again :-(
Yep - just downloaded it from your site.Did you install the stock app separately?
If the issue is still there with a different kernel, doesn't sound like the kernels fault. Reflash 1.4 kernel?
When did you last flash a radio? Camera is partly controlled by that too, believe it or big
