You should try the manu 2.1 I linked though as it does not drop power when screen off. At least that way you will know either way. If you stick with it, we'll need to add a script to modify your voltages though. No big deal.
Its a checkbox I cant get rid of. So I renamed it. It doesnt do anything, hence the name![]()
whats a superflous checkbox
EDIT: omg i fell for it
Yeah I'd give you a script to run along with 2.1 if thats what you're using. Sorry, are you? Couldnt quite work it out from that![]()
If you've not changed since flashing that's correct, except it's the dGB-customised version of the 2.1 HAVS-AXI-128-CFS that you have.
Ah ok.... Sorry
Just to clarify, there is a thread of Eviollet Kernels, of which the latest is ManU 2.1.
There is also a dGB 2.1 which Eviollet has tweaked for me specifically, based on ManU 2.1.
It was the former I suggested as this does not lower the WiFi power by default. This might determine if you were encountering your issues due to WiFi Lowering power when screen off.
One thing is ManU 2.1 has higher voltages than dGB 2.1 (This is one of the tweaks I asked for, voltages to be lowered) so if you were using ManU 2.1, we wouild need to compensate via a script. But as you are using dGB 2.1, there is no need to do anything.
Hope that makes sense.
This rom is just brilliant.
the voltages (nothing to do with WiFI btw, its about CPU - different tweak all together) will not be lowered
Flashed the downgrade hboot & the gingerbread upgrade RUU. Will try to get a repair under warranty. If sucessful I may or may not come back to dGB. I still think it is the ultimate ROM for the desire but I thought I understood what I was doing. Not so sure I do now!
Sorry Dan for hijacking your thread & thanks to you all for the help you have given so freely!
