Pitbull_Raven
Not really. Just install it if you want.
Tried. Didn't stick. Broke the rom.
Sent from my HTC Desire using Tapatalk 2 Beta-5
change the hboot,and you'll love it even more
I've got the 65mb hboot and I've downloaded and installed 56apps and still have 58mb space (that's with none moved to SD
Dgb is one thing I'll certainly miss when i upgrade at the start of June
Works fine for everyone else.
Are you installing it from SD card like a normal apk?
Free up a little bit more space.
I noticed that there is a dump for downloaded apps in /data/local/download. I quite regularly delete everything in there without any noticeable problems. I just make sure I have a titanium backup of trusted versions of my apps.
Never noticed anybody else mention this so feedback would be appreciated.
Yes. Wasn't working. Uninstalled current via TB and tried again. Didn't work. Tried installing with ADB. Finally worked. Now I am running into problems with space. Work related apps are hugeDarkTremor A2SD seems to break the rom (lot's of fc's and in terminal I can't run the a2sd commands) and Amarullz D2E doesn't seem to work either (also breaks the rom).
Yeah. I have way less. The problem is each of my companies apps are over 75 megs each. I went with move to sd. I just wish it would do so auto. Sad to hear we are losing yet another Desire dev. I'd upgrade too, but in Portugal as you know it's not as easy as, say, England.How many apps ave you got? "Move to SD" should easily be sufficient.
Ive got 131 user apps, 55MB free, and thats including my Work e-mail coming in.
Arrr I see, sorry. Probably should have mentioned I'm still on v1.3. Still feel I have no real reason to update, no market download issues, still great performance, still no rom hick-ups and I don't use a lockscreen.1.4 was the last version to use a data/local bind to cache. Its been expandable RAM disk for the last 3 versions.
My guess: a lot less than a Samsung Galaxy S3![]()
The Desire only has 802.1 b/g doesn't it ? (A quick trawl of Specs sites seems to agree with me). I suspect that's why your "n" isn't being enabled (and why SUroot should probably not waste his time supporting it).
I can confirm the n. Although I can't use it on pure 300mbps networks. Only networks up to 150mbps.It actually have the "n". I have just activated it, by pushing a file.
And I changed my router from g/n mixed to just n. And it's working
xda-developers - View Single Post - [KERNEL] data streaming/VOIP in standby, wifi module for HTC's OTA 2.6.35.10 kernel
Still loving this rom and just received my new HTC ONE X so space is no longer an initial.
Before swapping roms can someone answer/fix the following.
1. Sometimes during calls even with in call volume set to min it sounds like I'm using the loudspeaker! Not good in work.
2. Mobile signal and wifi seem weaker than the stock HTC
I don't see a big difference either. I'm checking with signal all the time. Have the feeling that it has a lower signal some of the time now.
But I'm connected with 72mbps just like the laptop, and not 54mbps like before.
Don't know why it wont go higher than 72mbps either on phone or laptop.
