Nooooooooooo! Steven!!! That's a recovery only file, not the system![]()
Yeah Gmail FC probably because that theme was using an older version.
As for just using the bar mod, it'll still kill the animations, as they're stored in the framework-res.apk file.
What types of things would cause you to need a recovery sbf flash or, conversely, to need a system sbf flash?
I've bricked before, but when would you use a system only vs a recovery only sbf?In short....to reflash your phone back to stock and recover from a brick
I have bricked many many times myself. When you mess up the system the device will turn on and you will see the Moto logo but thats as far as it will go. Thats when you would use the System SBF.
I have never ever had to use a Recovery SBF but that is supposed to be when your Recovery partition is damaged and you cannot boot to clockwork or the stock recovery.
GMB
Kind of a random Question but since ADW is built in, in this ROM ,,, what happened if I accidentally put an app in the app drawer possition, how do I get back my app drawer , any one knows?, am I missing some setting in ADW?![]()
p), then I reinstalled my other back up...
Yes! It's really easy as I had this problem too! Hold your finger on any empty space on any home screen, then go to add a custom shortcut, then proceed to pick your activity, then choose launcher actions and select "open/close app drawer", and viola!![]()
GMB
So... Say I am changing a file in the framework res working on a theme and screw something up and get caught in a boot loop. Would running the System SBF fix that?
That's one thing I am afraid of since I'm always messing around customizing themes to my liking and that has happened a couple of times. If all it would take is to run the System SBF to be back to running again I may have to give in and try this. I love Apex 1 and want to try this ROM, but that's the one thing holding me back right now.
There are more qualified people to answer that but as I understand it if it is looping from the boot animation that means there is incompatible data. Wipe data/cache and reboot should be fine.
I would only flash the system SBF if Data/Cache wipe didn't fix it and I would under no circumstances flash the Recovery only SBF unless you are 100% positive that your recovery is broken.
GMB
Does the Revolution theme work with this update?
I wanna know before I install it through ROM Manager.
Fabolous said:REVOlution Theme
-Works for both versions. Please do the following first! Go into settings, applications, manage applications, go to Market and Google Search, and uninstall updates for both!
Fabolous_REVOlution_ApeX_1_2.zip
I've just updated REVOlution for the 1.2 series. It's now available in the first post:
Install the same way as the ROM, don't wipe data or cache!
